Charging/Misfire Issue
Results 1 to 14 of 14
This is a discussion on Charging/Misfire Issue within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; OK guys, this car is killing me. I'm getting a misfire codes on all 4 cycl., around 2500-2700rpm is when ...
    Registered User cb6979's Avatar
    Apr 2008
    OK guys, this car is killing me. I'm getting a misfire codes on all 4 cycl., around 2500-2700rpm is when it is most noticeable and also the battery is not charging. My mechanic is saying it is the alt and the battery causing a low volt situation which in turn is causing my misfire. Well, the story is that I have swapped both units, cleaned all battery connections, grounds to the block/chassis, new plugs (.029 gap). Still having issues. Now my question to you guys is:
    A. Related problem?
    B: WTF. I know a fair amount about cars but this has me stumped.
    Any input would help
    again:
    New Batt.
    New Alt
    New Plugs
    Clean term.
    Good Ground
    New Belts
            MainFrame's Avatar
    Austin, TX
    What kind of EM are you running? What did the plugs look like when they came out? Were they white, brown, or black?
    Apr 2008
    Well the plugs were a very nice color brown which leads my to believe fuel wise, everything is good. The EM is bone stock. I haven't made it that far yet. As far as the computer, I'm not sure what it is.
            MainFrame's Avatar
    Austin, TX
    Yea, brown is good. Do you have any mods that you're not tuned for?
    Apr 2008
    Just a cold air
            MainFrame's Avatar
    Austin, TX
    Hmm.. that could be causing it to run lean, but with the plugs being brown I wouldn't think that it would be misfiring so bad like that.
    Apr 2008
    Yeah it ran fine for 5000 miles on it. I'm out of ideas
            MainFrame's Avatar
    Austin, TX
    Maybe bad coil packs?
    Apr 2008
    I tried swapping two and four pack as per these forums with no love. I checked them with a mutlimeter when i changed the plugs and they were within spec.
    Moderator timber's Avatar
    St. George, Ut.
    Is the alternator internally regulated on our cars? If not that would be my next guess...
    "Never Launched"
    Dougie
    - Founder, 250,000 mile club
    -5,000 posts
    Apr 2008
    I believe it is. I have put two of them on this car so I have ruled that out. The battery is 3 months old and tested good.
            MainFrame's Avatar
    Austin, TX
    That is perplexing..
    What plugs do you have? I've heard of problems with Champion plugs under boost, but since you're misfiring at 2500-2700rpm I doubt that's the problem.
    Hopefully someone with more knowledge about the issue can chime in.
    Apr 2008
    Good ole NGK V-power. I have never had any problems out of them. Humm
    St. George, Ut.
    I have a feeling that you are going to have to chase down a short ( or I guess it would be an "open") in your case. I would guess somewhere between the alternator/key switch or alternator/starter. What voltage are you reading at the battery with the car running?
    "Never Launched"
    Dougie
    -5,000 posts
