CEL P0108 Manifold Absolute Pressure High Input
Results 1 to 5 of 5
This is a discussion on CEL P0108 Manifold Absolute Pressure High Input within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Help!!! sorry also new to posting... Have finally managed to pull my code via scannet and a laptop and it ...
    Registered User RexDownUnda's Avatar
    Aug 2008
    Sydney, Australia
    Help!!!
    Have finally managed to pull my code via scannet and a laptop and it reads P0108 Manifold Absolute Pressure High Input
    Symtom is that when under boost, the car cuts out abruptly, and then continues ok if the pedal is eased off - if the pedal is held down, it will accelarete under boosts briefly, before cutting out again etc. (very embarassing when trying to ovetake...)
    -Subaru dealer have already replaced my MAP sensor.
    -I assum this not to be electrical, as it is only under boost that this seems to occur?
    Questions i then ask:
    -Could this be an air leak?
    -What is the best way to check for leak/s?
    -WHERE specifically do I check for air leak/s?
    sorry i am a novice diy and have very little idea of my engine
    any pics or detailed places to check would be greatly appreciated - or is there too many places to post pics?
    Thank you all so much in advance.
    RexDownUnda
    _______________________
    ~Subaru 4 life~
    Aug 2008
    Sydney, Australia
    Anyone?
    Anyone have any idea/s at all?
    ~Subaru 4 life~
    Aug 2008
    Sydney, Australia
    Forgot to mention...
    The engine is stock - no mods at all'
    ~Subaru 4 life~
    Aug 2008
    Sydney, Australia
    Not one for us amatuers....
    I thought this one was a little more complicated for us amatuers to try and diagnose / fix...
    Just thought someone might have some advice on how to check for pressure leaks (or most common places for a leak)
    You really would have to know the workings of a WRX engine to be able to point these out. Very complex I must agree !!
    Oh well ' Alas - I tried'
    ~Subaru 4 life~
    Aug 2008
    Sydney, Australia
    Smile Fixed!!!
    Ok guys n gals,
    Ok - this is the trick for a P0108 sensor code error :
    This usually occurs when a high voltage is detected in the MAP sensor. High voltage means either the sensor is kaput, or a high volume of air is passing the MAP sensor. In my case was a high volume of air, as my MAP sensor has already been replaced.
    What I foud was 2 leaks in the intake, and 1 in the vacuum.
    Fixed these, with replacement hoses, and now I can launch again !! No cut outs, no P0108 CEL light... !!
    Oh man I am happy - Have had this issue for 6 months + now!!!
    Yipeeeeeeee!!!!
    ~Subaru 4 life~
