Results 1 to 6 of 6
This is a discussion on Damn o2 sensor within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; i drive an 04 sti, the code read wen the CEL came on was P0171 system too lean bank 1. ...
    Registered User PRIMAJIN's Avatar
    Jul 2008
    Doylestown
    Damn o2 sensor
    P0171 system too lean bank 1. Out of the two o2 sensors on the car, how do i find out witch one needs replacing? i need help with this one, thanx alot fellas
    Is in Love With the Admins Here 20WRX04's Avatar
    Nov 2004
    WNY
    IIRC, bank one is the front one. Bank 2 being the rear one.
    The first rule of the Faction is...DO NOT TALK ABOUT THE FACTION.
    NY GIANTS
    Hybrid Faction #19
    Blobeye Syndicate #19
    Mods
    Jul 2008
    Doylestown
    o2 sensor
    awsome that is a huge help bra, do u happen to know the part # for the front sensor?
    Quote Originally Posted by primajin
    22641aa211
    Quote Originally Posted by PRIMAJIN View Post
    There is only one bank. "Bank 1" is simply a default.
    Don't. Instead:
    Clean your MAF.
    If you have an aftermarket air intake, fix it by fitting the factory unit. Check for vacuum leaks and fix them.
    Check the hose to the fuel pressure regulator.
    Check for leaks on the boost side too -- a BOV, incidentally, is a considered a leak -- and fix them.
    In all the instances of a PO171 I've seen, heard of, or read about, I think maybe two (if not just one) turned out to actually be the O2 sensor.
    Search PO171 for troubleshooting tips.
    For example:
    P0171 CEL Thread - Everything you ever wanted to know? - NASIOC
    If it turns out you cannot ID the problem, only then would I beg/borrow/steal a spare O2 sensor, fit it, and see if the CEL goes away. If it does not, go back to Step 1 and forget about the sensor (since that's not the issue).
    Nov 2004
    WNY
    ^^^ +1 on what SD_GR said.
    NY GIANTS
    Hybrid Faction #19
    Mods
