Results 1 to 3 of 3
This is a discussion on 03 wagon .029 plug gap? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Hey I push 20psi max...If I gap the plugs at .029 you think i will be ok at high rpm. ...
    Jun 2007
    Michigan
    reason i ask is because i have heard someone having problems at 22psi with their plugs gapped at .030
    Registered User rickyh's Avatar
    Apr 2004
    Metairie, Louisiana
    With a good set of plugs it should be no problem. I have a set of copper plugs (ngk BKR7E) in my car right now gapped at .30 with 19 psi on a 20g. I change them every six months but I have not had any problems related to the plugs.
    Jun 2007
    Michigan
    I am runnin NGK iridiums and thought it was straight but wasn't sure how it would react. Thanks for the input. keep it real man
