Oil pan slosh while hard braking
Results 1 to 6 of 6
This is a discussion on Oil pan slosh while hard braking within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; The title says it all. 2002 WRX, and I use Mobil 1 in it all the time. Not the synthetic, ...
    Registered User pfsquirrel's Avatar
    May 2008
    NJ
    The title says it all. 2002 WRX, and I use Mobil 1 in it all the time. Not the synthetic, as I got it with 36k miles on it, so I figured best not to switch from conventional at that point. So anyway, long story short, recently under hard braking, my oil light comes on. The only thing I can think of is possibly being a little low on oil, and it sloshes past the pump, not letting enough get sent out. When the car sits for a second, or directly accelerating, the light is off. Thoughts?
    May 2005
    Phillytown, PA
    Quote Originally Posted by pfsquirrel View Post
    So you checked the oil level, yes?
    SuperNova 06wrx4me's Avatar
    Jun 2006
    Nor Cal
    Umm I dunno how hard you are braking, but no your oil doesn't slosh enough to let the oil light come on. Unless you are ultra low on oil.
    2016 Challenger Scat Pack
    1973 Nova
    2014 Ford Fiesta ST <sold>
    COILOVER TABLE
    TURBO TABLE
    If your oil is at the correct level, suspect a vacuum leak that makes the motor want to stall under hard vacuum (as in, when you stand on the brakes and actuate the brake booster). Oh, and check the pressure sender I suppose.
    EDIT: You are NOT using Mobil1. All Mobil1 formulations are synthetics. If you are not using a synthetic, as you say, then you are using some other Mobil product. They come with various labelings and the packages tend to share the battleship gray used on M1 containers, making for a confusing product range.
    Registered User psychobooe's Avatar
    Mar 2004
    USAF
    Maybe he meant the Mobil Clean 5000/7500/High Mileage line of products from Mobil.
    Try not, do or do not. There is no try. - Yoda
    Mods
    Sure, those look a lot like the synthetics. Mobil have made it somewhat difficult to figure out quickly what one is actually buying. Works for them, I suppose.
