newby needs help
Results 1 to 6 of 6
This is a discussion on newby needs help within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Hi Im a new subie owner and I read in here about sea foam, well I put some in my ...
    Jul 2008
    newby needs help
    Hi Im a new subie owner and I read in here about sea foam, well I put some in my gas tank and I gained 85 miles to the tank not to mention it ran better, but now my cel came on any ideas what that could be?
    Thanks for any help
    Moderator Donkey's Avatar
    Da boonies,Va
    The obvious thing to do is get the DTC read and have it cleared and see if it comes back.Can't really help you unless you know what the code is.....
    2002 FORESTER S
    1998 FORESTER S
    Jul 2008
    help p0457
    Quote Originally Posted by memosuby View Post
    Thanks for any help
    hi again i had the cel read and it gave me a p0457 code what could that be, does anyone know?
    Da boonies,Va
    Gas cap.
    2002 FORESTER S
    1998 FORESTER S
    Jul 2008
    Thanks donkey i tried that and it worked Im glad it was something simple.
    Another question since im new to subarus and turbo cars how do you read the boost gauge, i have one that has 2 diff readings in psi in the middle theres a zero and it goes up from there on both sides, one side says vacuum and the other pressure what does that mean.
    thanks again
    Registered User falconflyer912's Avatar
    Dec 2007
    West Cheseter, PA and Mukilteo, WA
    The boost gague is just telling you the relative pressure inside of the intake manifold. Naturally aspirated motors would always read negative since they have to pull air in from that atmosphere.
    Turbo cars still operate under vacuum at lower RPMs and light load conditions. When a turbo spools and provides boost, that's when you'll see it go positive on the gague. The gague is just an easy way of seeing what's happening (and it looks pretty)
