I need help...
Results 1 to 8 of 8
This is a discussion on I need help... within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I'm driving down the freeway in my 06 2.5i at 65 with the cruise set. All of a sudden, the ...
    Registered User 321wings's Avatar
    Jul 2008
    I need help...
    I'm driving down the freeway in my 06 2.5i at 65 with the cruise set. All of a sudden, the car shifts down into 3rd, and I notice the ABS light comes on, but I hadn't touched the brakes. A couple seconds later, the needles dip a little bit when you turn the car off, and the stereo shuts off. A few seconds later it's turns back on, the light goes off and it's back to normal. I was only a few miles away from home and it was doing it all the way there. Once I hit my driveway, I shut it off to maybe reset something, and when I try to restart it, it acts like the battery's dead. It cranks for a second and the dash lights dims then stops.
    I jump started it, and it started up fine; however I saw that the odometer had reset itself. I haven't done anything to the engine, but I have had the gauge cluster out/apart recently so I'm sure I did something to it. Any ideas what?
    Sep 2005
    Milwaukee, WI
    Tough one, but I would say it sounds like a connector isn't fully seated to the cluster. Loss of power at the cluster (not at the battery) seems like to only logical explanation for the (trip?) odometer resetting itself.
    As far as the ABS goes and downshifting to 3rd I couldn't tell ya... Good luck though!
    Is in Love With the Admins Here 20WRX04's Avatar
    Nov 2004
    WNY
    I would check the battery. Then the alternator if it's not a loose connection.
    The first rule of the Faction is...DO NOT TALK ABOUT THE FACTION.
    NY GIANTS
    Hybrid Faction #19
    Blobeye Syndicate #19
    Mods
    Registered User KingDustin007's Avatar
    Jun 2008
    Peoria, Arizona
    Almost the exact same thing happened to me once, but in my nissan....It was the alternator...
    King Dustin
    Bugeye Mafia # 195
    Cobb Stage 2
    2002 PSM WRX
    Life's simple, you make choices and you don't look back. "
    Registered User Crb03's Avatar
    Jan 2008
    southern cali
    Quote Originally Posted by 20wrx04 View Post
    i would check the battery. Then the alternator if it's not a loose connection.
    +1
    "M3 drivers have no friends..." - Jeremy Clarkson
    "If something sounds too good to be true, it's best to shoot it to make sure" - Fiona Glenanne
    Jul 2008
    I checked around under the hood, and after running for like 2 minutes the alternator gets really hot. No loose connections on the battery, so I'm goin with I need a new alternator. Will the STi alternator fit? It's 90A instead of 75A, and since I'm running a stereo (1100 watts RMS), I might as well get the bigger one if it'll work.
    Sep 2005
    Milwaukee, WI
    Check voltage at the battery terminals with the car running. Should be around 14 volts. If you can pull your alternator on your own Advanced auto or Trak Auto or whoever should be able to check it before you replace it to make sure it's the problem.
    Registered User JUSTINSNUTSWINGER's Avatar
    Jul 2008
    San Antonio
    Still under warranty ?
