Im assuming theres no check engine light (ie cylinder misfire)? Any black smoke or heavy gas smell from exhaust (running rich)? Someone more knowledgeable than I might provide more insight to you, however my 02 Rex was idleing roughly, kinda rumbling at 620-800 RPM, so i put some sea foam through the vacuum lines. after a good smoke show and a day of misfiring afterwards due to fouled plugs, my idle is now a smooth 710-720 rpm and i had a noticable increase in low end torque.
LinkBack URL
About LinkBacks
