Results 1 to 15 of 22
This is a discussion on 08 WRX getting check engine light at 5K RMP and loss of power... within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; ***Car info*** 08 WRX with: SPT exhaust Cobb street downpipe Stage 2 map via AccessPORT Running 16 PSI boost Car ...
    Aug 2008
    ***Car info***
    08 WRX with:
    SPT exhaust
    Car has not been tuned
    **Problem**
    I am getting a check engine light after 5000 RPM and my car will jolt. I lose most engine response at this point, the car loses nearly all throttle and engine response like it’s bogged down. This is when Traction Control is ON and the throttle is used aggressively at high to max boost levels. If I use the throttle passively the car works fine through the entire RMA range. I tried the same thing with Traction Control OFF and had the same issue but less frequent. I apologize; I have not had an opportunity to get the check engine codes so I don’t have any info on that. Any advice on what’s going on and how to fix it would be greatly appreciated.
    Quote Originally Posted by LegendWRX1111
    Use the AP to pull the CEL codes, then we can help from there
    Aug 2008
    I installed an AEM cold air intake the same day I opened this post and have not had any issues. I've tried to make the check engine light come on again but nothing. The cold air intake seems to have fixed the issue. Do you think the car wasn't getting enough air and was getting bogged down?
    Aug 2008
    Colorado Springs, CO
    Does your traction control light, check engine and cruise light come on when this happens? If so, I am having the same problem since I installed the new turbo back exhaust
    Aug 2008
    Quote Originally Posted by whec2018 View Post
    Yeah, that’s what I was getting. I heard a rumor that it may be an issue with the waist gate causing this. If you have an AccessPORT you can pull the check engine light code to confirm this. I can't get it anymore but if you can get it and post it we hopefully can get some good info on what’s going on. List any other mods you've done so we have a good idea of what may be going on.
    Aug 2008
    I just read your "Wastegate solenoid code" forum post. It does sound like it's a waste gate solenoid issue caused by over boosting. When you put on your cold air intake your issue may go away. This is what I noticed anyway. I'm hoping someone can confirm if this may have been a lack of the amount of air coming into the engine.
    Aug 2008
    The code is:
    PO244 MOD$00
    Turbo/sup Wastegate
    Solenoid A
    Range/Performance
    I pulled this with my OBD2 scanner. I can reset it and the car is fine until I try to accelerate hard in fourth or fifth gear and it will do it again. Once the lights are on, I can accelerate as hard as I want to and it runs fine. Hopefully the intake helps.
    PO244
    Overboost
    Aug 2008
    Quote Originally Posted by idipskoalmint View Post
    Overboost
    What do we do to resolve this problem? Is the cold air intake a solution? I am planning to add more boost soon. Am I going to see this problem again? If so should I get a stronger waist gate? I’m not sure what the stock waist gate is rated for.
    That means there's a cat, correct?
    Aug 2008
    Correct, its got the high flow cat on it.
    Aug 2008
    OZ
    what to put on
    can I get some help I just won $7000 and I want to put it all on my car a wrx 2006 I want it to go faster I already have coilovers on it and new rubbers what next exhast frontmount plzz somebody help me..... many thank if you can
    Registered User DubleUaReX's Avatar
    Oct 2005
    Galena, Ohio
    Quote Originally Posted by filo69 View Post
    Holy Crap?!? First time on the internet? Many thank if it is.
    Aug 2008
    I have the high flow cat also(basically it is just an open pipe from TurboXS) I will be installing my cold air intake tomorrow so we will see if this helps. I don't know how to adjust the boost.
    Aug 2008
    Keep me posted on if it fixes the problem whec2018.
