Need Help
Results 1 to 11 of 11
This is a discussion on Need Help within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I am trying to replace my rotors on my 2002 WRX and cant seem to get them off. Any help ...
    Registered User stockscooby's Avatar
    Apr 2006
    wisconsin
    Need Help W/Brakes
    I am trying to replace my rotors on my 2002 WRX and cant seem to get them off. Any help would be great. Thanks guys
    Registered User jeffmm06's Avatar
    Sep 2007
    Sacramento, CA
    You have the calipers off I assume?
    Hit them with a hammer to break away and rust thats causing them to adhese to the hub. If its the rear rotors try disengaging the hand brake.
    2005 WRB WRX "was" STAGE 2
    Apr 2006
    wisconsin
    Quote Originally Posted by jeffmm06 View Post
    Yes the calipers are off. I have not made it to the backs yet. Does the big nut in the center of the hub have to come off?
    Sep 2007
    Sacramento, CA
    It doesnt on my 2005 wrx.
    Take a hammer to the hub portion of the rotor. Hit in a few spots, see if the breaks it loose.
    Apr 2006
    wisconsin
    I'll take a look when I get home... Come on people, all you do it yourselfers out there and nobody has taken off there rotors??
    Registered User Ballsdeep18's Avatar
    Jul 2008
    Bel Air, Md
    All you have to do is take the calipers off. and then if you cant get them off try using a dead blow hammer and just knocking off the rotor, and when you get to the back just make sure you have the E brake off
    Apr 2006
    wisconsin
    OK, so I don't need to take the big center nut off?
    Sep 2007
    Sacramento, CA
    no
    Registered User p0rnstar19's Avatar
    Gaithersburg, MD
    a hammer maybe a little of 401.
    Quote Originally Posted by LPPTundWRX View Post
    ^^^Your sig is bull****....
    Quote Originally Posted by Integra96 View Post
    Is that a euphemism for a meat helmet?
    Apr 2006
    wisconsin
    2002 WRX Rotor Removal
    Thanks for the help guys I got it. In case anyone else needs help. 1) You take off the tire
    2) take out 2 bolts holding the caliper
    3) take caliper off "make sure its not just hanging down, tie it up if you have to"
    4) remove 2 bolts holding caliper bracket
    5) Hit rotor from back side with hammer until broken loose. "turn rotor if needed while hitting with hammer.
    Jul 2008
    rotor help
    Hi I just changed my rotors on my 02 and they were hard to come off so I read somewhere that theres a hole and its threaded screw a bolt in there slowly backing it off every so often then just work it out and it should come off pretty easy that way.
    Good luck
