Ok, so it's not the alternator - what is up now? - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 23 of 23
This is a discussion on Ok, so it's not the alternator - what is up now? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; idler pulley, eh? ive been pondering this for a couple weeks, trying to make sense of it all, and im ...
    Sep 2006
    idler pulley, eh?
    ive been pondering this for a couple weeks, trying to make sense of it all, and im back to thinking it might be the alternator. im just wondering if its not working properly after warming up, as initially the car is fine. i would imagine if it was something like a pulley it would be off all the time.
    im thinking now that when they tested the alternator it wasnt hot enough to be 'failing'.
    if anyone else has had funky idling, did you notice your voltmeter was reacting as well?
    Registered User WyleyStubz's Avatar
    Aug 2008
    Georgia
    i didnt realize the voltmeter acting up... my mechanic buddy and i widdled it down to one of two issues w/ my car. it's either the ac compressor or the pulley. the pulley was really gnarly, so i changed that first. it's been a couple days and hasnt acted up yet. if it does i know its the ac compressor. in my case i know it was something with the ac, b/c once i took of the ac belt, and ran without ac, the car ran perfectly fine. it didnt stall once. i hope that helps.
    Aug 2008
    Colorado Springs, CO
    You could be right about the alternator not messing up until it gets hot. Try to drive it around kinda hard for a while and when you notice it messing up take it somewhere to get it checked. Unless the idle is moving around a lot, you shouldn't see the amp gauge change. It almost has to be a bad alternator or a loose wire somewhere. (maybe at the fuse box, battery or the gauge itself.
  6. #19
    Sep 2006
    Quote Originally Posted by whec2018 View Post
    ive thought about this so much in the past couple weeks, it is literally driving me nuts... (no pun intended)
    however, the more i think about it, the more i think it has to be electrical related, otherwise, i dont think the voltmeter would do anything until the idle got REAL bad, which i guess it never really does.
    where are some wire grounds i can check out?
  7. #20
    Aug 2008
    I would follow each of the wires from the batters and wiggle them around any where that they have a connection and then check at each of the fuse boxes and make sure that the power feeding to them is tight. Also make sure your ground from the battery to the frame and to the block are good and tight and there is no corrosion on any of these wires.
  8. #21
    Is in Love With the Admins Here 20WRX04's Avatar
    Nov 2004
    WNY
    rudemood12, you've been dealing with this issue for over a month. I highly suggest taking it to a Subaru dealership for professional service. Boom, whack, done.
    The first rule of the Faction is...DO NOT TALK ABOUT THE FACTION.
    NY GIANTS
    Hybrid Faction #19
    Blobeye Syndicate #19
    Mods
  9. #22
    Registered User DstrbdTech's Avatar
    Aug 2008
    How old is the car.... Has you're throttle body ever been cleaned?
    My Sentra had a rough weird idle issue but it was solved relatively easy by simply cleaning throttle body. Removed the intake...sprayed the cleaner on it dried it light spray with the car running reattached intake and no more weird idle.
    Just a thought dunno if this might be a subaru only thing.
  10. #23
    Sep 2006
    Quote Originally Posted by 20WRX04 View Post
    yeah, i might just have to do that anyways. i was hoping to be able to resolve this myself, but lack of time/work area will probably mean this is inevitable.
    dstrbdtech, they cleaned the throttle body last time i brought it into the shop, using the TSB they released on it. removed the intercooler, sprayed some stuff into the intake, etc. didnt seem to do the trick.
