Boost solonoid
Results 1 to 6 of 6
This is a discussion on Boost solonoid within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Can anybody help me? I have a 3 port solonid ,do i need the restrictor pill in or not? I ...
    Registered User SILLYBILLYS WRX's Avatar
    Jul 2008
    UK
    Boost solonoid
    I ran it with it in ,but only boosted at .7psi
    when ran with out ,it ran at 1.2psi, is is safe to run without?
    Cheers chris
    Aug 2002
    Virginia Beach, VA
    What boost gauge are you using? If you're running the stock turbo wastegate, it's not possible for boost to only be 1.2 psi...it would run up to 9 psi if you hade everything installed improperly. What other mods do you have? What engine management are you using? It is not safe to run a 3port solenoid without ECU tuning...
    Jul 2008
    UK
    Quote Originally Posted by Timdog1650 View Post
    my boost gauge reads from -.09 to 1.5spi? i m just going off that,i running stock turbo wastegate.no mods standard uk car.apart from ppp pack. i only changed to 3 port solonoid as mt 2 port ,went faulty and didnt think it would make any difference, if all pipe work piped up correctly.
    should i get a 2port standard solonoid?
    Aug 2002
    Virginia Beach, VA
    Okay, those are not PSI marks, they're "bar." 1 Bar = 14.5 psi. If you're hitting 1.2 bar, you're overboosting. I would recommend you go back to a stock boost control solenoid OR get a tuner to rescale your boost map in your ecu to work with the 3 port. The three port is a good choice for faster spool, but does not work on an ecu that is not calibrated for it.
    Registered User Findus11's Avatar
    Nov 2007
    Ketchum, Idaho
    hey man my 07 is only boosting that #
    all my hoses are good i think (dunno really)
    do I have a faulty boost gauge?
    Hawk Eye #1991
    Dirty Crew #11
    Military Militia #1991
    I still don't know how I got this car...
    Moderator Donkey's Avatar
    Da boonies,Va
    Quote Originally Posted by Findus11 View Post
    Re-read Timdogs last post first.Now what frigg'n boost gauge do you have?Is it the stock Lamco one that reads in bar?
    2002 FORESTER S
    1998 FORESTER S
