Some have replaced the water pump, and belt tensioners, also would be good to inspect the seals. The belt is the only REQUIRED part to be replaced, but it can be a wise decision to do more as preventative.
This is a discussion on Question about/ upgrading within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Hello everyone, I am due to replace my timing belt. I was just wondering if anyone had any suggestions on ...
Hello everyone,
I am due to replace my timing belt. I was just wondering if anyone had any suggestions on what else should be done while under I'm in that area. Pulleys?
2005 WRB WRX "was" STAGE 2
I was more thinking about other bolt on pats in the area of the engine. Would buying aftermarket pulleys or changing the size increase the power/ performance?
