1 problem and 1 question!
Results 1 to 6 of 6
This is a discussion on 1 problem and 1 question! within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Would really apprieciate this: 1. How many quarts of oil should i put in to it when changing it? 2. ...
    Jul 2008
    SoCal
    2. My central locks on it don't work, I can only lock one door at the time, from inside my car. Can it have something to do with my alarmsystem, cause it ain't working correctly either?
    For exemplem, if I would to lock passenger door from outside when the door is open and then close it, alarm will go of when i open it.
    Thanks / Tim
    Oil capacity varies depending on the model year but is always listed in the owner's manual.
    Yes, the door issue and alarm issue can be related.
    Registered User 02_Rex's Avatar
    Feb 2007
    Is it an after market alarm? or is it what came with the car from subaru?
    Huh... Didn't know you couldn't do that...
    Jul 2008
    SoCal
    Hey, thanks for htips and troubleshoting, yeah it is the alarm that came with the car.
    Thanks / Tim
    Registered User 06PearlWRX's Avatar
    Dec 2006
    SoCal
    if your power lock button doesn't run any of the locks, i would check the fuse controlling it to start with. its probably the same as the power windows.
    does it actuall lock and unlock the doors. because the other problem about the alarm going off just sounds like the remote is not unarming the alarm.
    "90 miles an hour through trees sideways is pretty damn scary" ~Ken Block
    Jul 2008
    SoCal
    thanks, but my unlock/lock buttomfrom driverside can only lock the driverside and passenger side, not the 2 backdoors.
    Oh thx, i'll check the fuses and ill get back to ya.
    Thanks / Tim
