HID problem
Results 1 to 7 of 7
This is a discussion on HID problem within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Hi, I just put on some 10k HID's on my 07 wrx. They work fine and all but they will ...
    Mar 2008
    HID problem
    Hi, I just put on some 10k HID's on my 07 wrx. They work fine and all but they will not turn off. The only way the turn off is if i turn the light lever to the off position and have the handbrake pulled up. If i drive around they are always on, regardless wether or not the switch is off kinda like the daytime running lights. Any ideas?
    Thanks
    2007 wrx ltd. crystal grey. Stage 2 YAY!!!!!
    You have apparently not disabled the daytime running lights.
    - Al Stewart
    Mar 2008
    I see....where is that exactly? Or how would I go about disabling the daytime lights? Why is it linked to my main headlights because the stock bulbs didnt exactly do this to me?
    Thanks for the response
  5. #4
    Quote Originally Posted by deli pastrami View Post
    Your previous statements indicated the stock bulbs did in fact behave the same way.
    Better DRL method
    and
    Question Regarding '07 DRL's *Pics*
    - Al Stewart
  6. #5
    Mar 2008
    Thank you very much, I will try this now!
  7. #6
    No problem, good luck. Previous years were easier to deal with. I'd not do anything I could not easily reverse, as the second thread is quite long and several people take different approaches. Careful.
    - Al Stewart
  8. #7
    Mar 2008
    right. After reading through most of the possible fixes I found the right one for me. Turns out the 07's were a bit trickier to take off DRL's.
    I used this:
    http://www.clubwrx.net/forums/1987347-post1.html
    and this:
    NASIOC - View Single Post - 2007 DRL disable different than 2006?
    for reference and about 30 minutes later I had finished. The pin actually got jammed so that took the longest because I had to find a gentle way to ease it out. My DRL's are gone, the "always on HID's" are also gone. Everything worked out. Thanks again
