Results 1 to 14 of 14
This is a discussion on royal purple (worth it?) within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; is it worth switching my oil out for this stuff?? will it make that much of a difference??...
    Registered User xmikex's Avatar
    May 2008
    cali
    Scooby Hooligan
    Weasel 555's Avatar
    UK,NY,AK,FL
    i wouldnt but thass just my opinion
    engine 5-30 winter , 10-30 winter (Mobil 1)
    tranny n diff ---i use subaru genuine , i once tried mobil 1 and talk about a whiney tranny and diff whoah ! switched back to the subaru genuine so much nicer
    ScoobyDMC #000,HawkEyeAlliance#000,Blobeye Syndicate #000, SQC-NY #009, "Dragon Slayer"
    "All We'll Drive"
    I <3 boobies: rallyarmor/keepabreast/mud flaps limited edition
    Quote Originally Posted by xmikex View Post
    A difference in what?
    Resident meany-rator 06wrx4me's Avatar
    Jun 2006
    Nor Cal
    Its not recommended by Subaru for 06+. Check to make sure it meets all the applicable ratings necessary for your car. You can find them in the manual.
    Registered User Acrdys's Avatar
    Jun 2007
    Lemore
    funny i was thikning of using royal purple also...
    06wrx4me is all over on this topic :P saved me from doing something dumb today.
    Hawk-Eye Alliance#8089
    MODS LIST
    May 2008
    cali
    when i back up my tranny whines do subis do that or is it caused by the oil like Weasel 555 said?? and i am new at this and this may be a dumb question but when you get your oil changed at the dealership do they use the subaru genuine oil there?? or do you have to specialy buy it and put it in??
    Are you now talking about the gearbox then? And are you now talking about gear oil?
    Check out the gear oil thread. It has info from numerous users and analytical data.
    Jun 2006
    Nor Cal
    The link to that thread is in my sig...
    Jun 2007
    Lemore
    whine when you backup is normal. I just drove a civic SI today and it would whine like crazy going in reverse. The toyota truck i practiced with makes the same whining sound.
    As far as i know, when you take it in for service they do everything for you.
    MODS LIST
    Registered User jeffmm06's Avatar
    Sep 2007
    Sacramento, CA
    All manual gearboxes make that noise. Your gears 1-5 are helical (cut on an angle) this causes there to be no whine while the gears mesh together. The reverse gear is a spur gear (straight cut) therefore the noise will exist. All reverse gears in a manual trans will make that sound...no worrys.
    2005 WRB WRX "was" STAGE 2
    Registered User viperhd's Avatar
    Dec 2007
    LI NY
    What differencial oil shuold i use??
    I have a 06 WRX with 23000 miles on it and want to change the front and rear diff fluid whats the best to use????
    Quote Originally Posted by viperhd View Post
    See above:
    Quote Originally Posted by 06wrx4me View Post
    Apr 2008
    teh OC
    front diff shares the same fluid as the tranny. so any GL-5 will do. If you want good stuff, try Subaru S, Motul 300 or Amsoil Severe gear. they're all in the 75-90 weight range.
    for the rear, use whatever you like or is cheap. i'm using amsoil in the tranny/front diff and valvoline in the rear diff.
    "Let the ingorance die with the ignorant"
    Registered User Alpentalic's Avatar
    Sep 2005
    For what it's worth, I had a bad syncro ring grind when shifting into 4th in my 04 wrx. It was suggested to me that I replace the tranny fluid with amsoil severe gear, motul gear 300, or redline lightweight shockproof.
    I ended up going with the shockproof and the grind is completely gone. Just changing the fluid saved me a tranny rebuild. I can only imagine that if it works this well for a tranny that has noticable issues, that it would be doing good things in a tranny with no known issues as well.
    2004 Java Black Wagon
    Mods - VF39, '06 WRX Injectors, Cobb OTS AP Map, Perrin Up & Down Pipe, DC Sports Catback, Cobb LWC Pulley, STI Hood Scoop, Sprayer & TMIC, Kartboy SS, Cleared Headlights & Aftermarket Leather Interior W/Heated Seats
    Bobby Tuned - 286 awhp/265awtq
