Low boost only 5-6 psi problem
Results 1 to 5 of 5
This is a discussion on Low boost only 5-6 psi problem within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Im having boost problems on my wrx,ive checked all pipes around turbo and boost solonoid,its drivin me crazy.can any body ...
    Registered User SILLYBILLYS WRX's Avatar
    Jul 2008
    UK
    Red face Low boost only 5-6 psi problem
    Im having boost problems on my wrx,ive checked all pipes around turbo and boost solonoid,its drivin me crazy.can any body help please.??
    May 2007
    orlando flawduh
    what modifications do you have
    desiree
    Jul 2008
    UK
    Boost problem
    I have no engine mods,standard .i changed to a 3port solonoid,i thought it was that.it may be that the boost pipes are in wrong position.?
    Jul 2004
    Seattle, WA
    If you don't have any engine mods, I'd suggest putting the stock boost solenoid back on .
    Then check the other lines.
    Registered User adizzle02's Avatar
    Mar 2008
    Sandy Utah
    Quote Originally Posted by SILLYBILLYS WRX View Post
    im sure you may have seen this but its a good reference for where the hoses go for the stock bcs CobbTuning.com - How Subaru’s Factory Boost Control System Works
    as suggested i would try putting the stock bcs back on and see if the problem goes away. I was having the same low boost problem with mine and it turned out that my stock bcs was bad.... it also wouldnt hurt to check out all the boost lines to make sure that there are no cracks or anything
    VF39'd and Clark Tuned
    BugEyeMafia #176
    Basshead Member #3
