Running problems
Results 1 to 4 of 4
This is a discussion on Running problems within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Hi everyone im looking for some help my 94 sti the car is slow to start and needs a bit ...
    Jul 2008
    IRELAND
    Running problems
    Hi everyone im looking for some help my 94 sti the car is slow to start and needs a bit of throttle to get going once its running its ok until you floor it the turbo kicks in for about two seconds but cuts out again really sharply if im gently with the throttle and feed it on everything is fine any ideas?
    Registered User jeffmm06's Avatar
    Sep 2007
    Sacramento, CA
    Tune up?
    Throttle plate cleaning?
    Plugs? Hows the fuel pressure?
    Id check things of that nature first...
    2005 WRB WRX "was" STAGE 2
    Jul 2008
    IRELAND
    running problems
    Thanks Jeff, il do the throttle plate and plugs this evening how would i test the feul pressure?
    Sep 2007
    Sacramento, CA
    Im not saying these things need to be replaced but should definetly be checked, a fuel pressure gauge could be used, generally there is a T in the fuel hardline, where you could check it at under the hood. Im not to familier with it on these cars, i say that because maybe you have a clogged fuel line, or maybe a clogged fuel filter.
