How long will a can of brake fluid last?
Results 1 to 2 of 2
This is a discussion on How long will a can of brake fluid last? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; After the seal has been broken... I know it absorbs moisture. Does this still happen even if you put the ...
    Registered User Pavia's Avatar
    Dec 2006
    Philly/DE area
    I know it absorbs moisture. Does this still happen even if you put the cap back on properly?
    06 GTO M6 Quicksilver, SLP 455 Bobcat, LS7 Clutch w/ SS line (RPM tune:373rwhp/373rwtq)
    07 WRX TR M5 Garnet Red Pearl w/ Straight PPGs and Cusco front LSD (Agile tune:307whp/343wtq)
    Mace Windu devilfluff's Avatar
    Feb 2005
    south jersey
    Brake fluid will pull moisture from the air w/ the cap on unless you get an airtight seal. But IME w/ a good seal, it will be a very slow process and should last quite some time. (at least a year, if not longer)
    Dirty Jersey
    Part-Time Grammar Nazi
    RIP- '02 PSM Wagon
    SOLD- 08 Candy White MK5 GTI 6spd
    '15 WRB BRZ Limited, 6spd
    Moderator:Tri-State and Transmission & AWD forums
