Image of Engine cleaner - Photobucket - Video and Image Hosting Just take that hose off and suck the seafoam up into it.
This is a discussion on Seafoamage but where? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; so ive added seafoam to my tank but i really wanna get it in all the cylinders for that smoke ...
so ive added seafoam to my tank but i really wanna get it in all the cylinders for that smoke storm. My rex has 64K on it so im hoping there will be a bunch of gunk.
My question is where can i best feed it into the intake? I was told to suck it up through the BPV line? I have a boost gauge taped into the BPV so do you think i could just yank that hose out and let the vac suck it in?
And what about adding it to the crankcase? Do you really need to change the oil after?
Thanks for reading (Pics would really help if possible)
'02 WRX 4EAT, 311,000KMs/194,500Miles, Sold. Best car I ever had.'09 STi stage 1, hope this one will be good too...
just curious, I own a NA 03 legacy... where is the best place to do it on a non turbo car?
okay...use the vacuum line attached to the brake booster. that is the easiest one to use.
Most people suck in the sea foam until the engine stops...i prefer to suck up the sea foam and rev up the car so it doesn't die. you will definitely get a smoke show. i could not see my neighbors house it was so smoky!
IMO this is the best method:
1 bottle goes into a 3/4-Full tank of gas.
When you get down to about the last 1/4 tank or so, or within about 100-150 miles left in the tank, put half a bottle in your crankcase.
Go ahead and refill your tank and get new oil/oil filter/air filter/whatever. Use the other half you have saved, or even a whole new bottle to suck up into your engine using the vacuum line. This will clean out all the carbon, you can even smell it burning off. If you don't see much smoke, you have a pretty clean engine..if you see a lot...then you need to keep fogging out your neighbors until it is a little clearer.
Your car will probably feel amazing after this. to answer your question, Yes, you will need to change your oil because it is going to be extremely dirty/thin with all the sea foaming you just used
Good luck!!! any specific questions about it, shoot me a PM
if you put it down where the brake booster is attached, then the seafoam will only go to one cylinder.
if you use the bpv hose then you might get an even distribution, but the design of the intake manifold looks like it will only allow the seafoam to enter only 2 cylinders. a spot that i tried was where the vacuum hose attaches to the front side of the inatke manifold
SOCAL F4#02 OG member
2002 PSM WRX stage 6
2007 Kawasaki Ninja ZX6R
ok so which vaccum line should I use on my NA engine to feed all the cylinders?
