03wrx not reading gas level
Results 1 to 10 of 10
This is a discussion on 03wrx not reading gas level within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; i have a 03 wrx stock drives good just not reading the gas, fuel guage reads empty CEL is on ...
    Registered User 03**EJ20's Avatar
    Jul 2008
    san jose,ca
    Unhappy 03wrx not reading gas level
    i have a 03 wrx stock drives good just not reading the gas, fuel guage reads empty CEL is on hooked up OBDII and says PO462&463 fuel level sensor i replaced it with a used one and still nothing fuel guage is fine tested it and, finally i realized i should check if theres any power to the unit no power to sensor just fuel pump so im wondering if its the harness or some kind of relay,if so were are they located, im all out of ideas so if anybody could help i would appreciate it
    May 2007
    behind the wheel
    WTF are all these non-punctuated posts about, all of a sudden? This is like the fifth different post, this morning, that lacks any form of punctuation..
    Welcome to ClubWRX.
    #1: Service manual can be your friend
    #2: See #1
    Rogan o_0
    Jul 2008
    san jose,ca
    Thanks will do,but do the wires run under the car or inside. I have the manual and it doesnt tell me, also what do you think it is?
    Administrator
    May 2003
    Quote Originally Posted by 03**EJ20 View Post
    Inside
    Administrator
    May 2003
    Also, have you unbolted any ground wires/straps lately or removed the transmission recently?
    Jul 2008
    san jose,ca
    No, where is the ground wires its hard to understand where they are located
    Administrator
    May 2003
    Has any work at all been performed on the car recently?
    Jul 2008
    san jose,ca
    i bought the car from a auction. It was crashed from the back,and the rear quarter panel was replaced.
    Jul 2004
    Seattle, WA
    Best to check all the external connections on the gas tank.
    Was/is there any damage to the gas tank? Was it replaced?
    Jul 2008
    san jose,ca
    The gas tank was not replaced, what do you mean by external gas tank connections
