My '03 has the same cranking problem. Same as you, about once a month. I didn't notice anything with the headlights though. Does anybody else have this problem?
This is a discussion on occasional electrical problems within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; so i have an 05 WRX wagon with this intermittent problem with my electrical system. About once a month it ...
so i have an 05 WRX wagon with this intermittent problem with my electrical system. About once a month it hesitates to start, it will crank and crank, but not turn over. After a few cycles it will finally turn over. In addition to this at night sometimes my head lights will temporarily dim slightly. My only guess is there is a loose ground somewhere...any other ideas, or where to look?
yes my 04 headlights dim sometimes when i signal left or right. it hasn't happened lately but in the past it was fairly common. I've had trouble starting my car as well but i assumed its because it was winter and the cold was not good for the battery which was a few years old.
I have had the same problem with my 2003 WRX but along with the head lights the lights inside the car dim for about 15 seconds.
