Oil pressure problem
Results 1 to 6 of 6
This is a discussion on Oil pressure problem within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I changed my oil, made sure it was filled up perfectly. I have a 18g turbo set up. My oil ...
    Registered User Az subie's Avatar
    Jun 2008
    Phoenix, az
    I changed my oil, made sure it was filled up perfectly. I have a 18g turbo set up. My oil pressure idicator drops below 20 and starts beeping. So can anyone tell me why it might be dropping below where it should be? Any help much appreciated
    Is the viscosity of the new oil identical to that of the oil you replaced?
    Where is the oil pressure sender connected?
    Jun 2008
    Phoenix, az
    Ya its the same oil and everything. What do you mean by where its connected?
    SuperNova 06wrx4me's Avatar
    Jun 2006
    Nor Cal
    Do you have a leak?
    Is oil pouring out of your exhaust (could be blown turbo seal)?
    Could also be that the oil pickup tube is plugged with gunk on the bottom.
    Also check the AVCS bolt screens. Their was a TSB for them.
    2016 Challenger Scat Pack
    1973 Nova
    2014 Ford Fiesta ST <sold>
    COILOVER TABLE
    TURBO TABLE
    Jun 2008
    Phoenix, az
    There is no leak going on. Might be the tube. Guess i gotta take it in to the shop
    Aug 2002
    Virginia Beach, VA
    Quote Originally Posted by Az subie View Post
    That's your best bet. If you literally did not change anything at all, it's probably a faulty gauge. Oil pressure doesn't just die for no reason.
