WRX Missfiring
Results 1 to 5 of 5
This is a discussion on WRX Missfiring within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I rebuilt my 2002 wrx and now when i run it, it is missfiring. I scanned it and i got ...
    Jul 2006
    WRX Missfiring
    I rebuilt my 2002 wrx and now when i run it, it is missfiring. I scanned it and i got P0301, P0302, P0304. SO i deleted the codes and scanned it again and i got P0301, P0302, P0303. I dont know why it is doing this. I am thinking it is my timing but i wanted some suggestions. Thank You.
    Moderator Donkey's Avatar
    Da boonies,Va
    Quote Originally Posted by smitt04 View Post
    Jebus people.There needs to be a sticky on how to ask a technical question.
    1) Helps if you list all your mods
    2)Give a descriptive and detailed timeline of events
    IE: "It has done this since I bought the car"
    "I just installed an air intake and had no CEL originally when I started the car after the install.Now after 1hr of driving I have a CEL and the DTC # is P0xxx"
    Did you recheck to see if the timing marks line up?What plugs are you using and what gap?Also you cannot switch up the coil pack harness.The harness connections are specific to the cylinder.
    2002 FORESTER S
    1998 FORESTER S
    Jul 2006
    The only mod i have is a cold air intake. The whole problem happened when i blew a spark out of my head. I took of the head and sent it to a machine shop to get it fixed then i put my car all back together. As soon as i start my car i can tell it is not running on all 4 cylinders. The DTC codes are as i stated above.
    Aug 2002
    Virginia Beach, VA
    Did you do any of the work or was it done for you? Did you do the motor job? Did you use the factory service manual for removing/reinstalling the heads?
    Da boonies,Va
    Sounds like the cam timing is off.You will have to check to see if the cam gear timing marks line up when the #1 cylinder is at TDC.
    2002 FORESTER S
    1998 FORESTER S
