just use the loan a tool program at your local autozone and ask them for an O2 socket. I just used an adjustable short wrench though and it worked fine for me. Just be careful with it.
This is a discussion on front 02 sensor within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; My wrx is throwing the check engine light and when i checked the codes It ended up being the front ...
My wrx is throwing the check engine light and when i checked the codes It ended up being the front 02 sensor. I wondered if anyone knows what size socket the sensor is so that I can get the slotted one to fit the wire?
ok cool thanks for the help
17mm I believe.
bigger than that. the threads are 18mm. I believe it's 22 or 24mm.
Rogan o_0
'01 Dodge 2500 CTD 6-holed hand-shaker - 3850# dual disk
'97 Dodge 3500 CTD DUALLY built Auto - 40psi boosties
