Results 1 to 15 of 17
This is a discussion on Check Engine light within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Hey everyone I got a problem with the wrx and looking to see if anyone can help a subie newb ...
    Registered User mdwstinnovation's Avatar
    May 2008
    Elgin, IL
    Check Engine light
    Hey everyone I got a problem with the wrx and looking to see if anyone can help a subie newb like me. Well here what happened, I turning out from a red light, and had the car in first. I took the car to about 5000 rpms, and shifted into second, and the car jolted me forward as if I hit the breaks. I had my foot on the gas, but the car wouldn't move, and the the car died and the check engine light came on. I've had this happen a few days ago, but the car did not die, I just took it out of second then put it back into second and it ran fine. I don't understand why this is happening. I just had the motor replaced a couple weeks ago, and did the break in period for 1000 miles. So if anyone knows why this is happening that would be greatly appreciated.
    Thanks,
    JT
    Apr 2007
    8000' up in Colorado
    You don't give enough info to go on. What mods (if any) does the car have? Did you hook up to an OBD2 reader and pull the codes? Why was the motor replaced and who did it? Any other issues during the break-in period?
    Scott
    Aug 2002
    Virginia Beach, VA
    Post your mods/model year/and the number of the code you're getting. Don't rev past 3500 until you solve the problem or get some advice from someone on here; you don't want to make anything worse if you have an issue with the engine.
    May 2008
    Elgin, IL
    Delete post!!!
    May 2008
    Elgin, IL
    Sorry guys about the last post my internet is down at home and I tried to use my blackberry, but it obviously didn't work too well haha. Anyways its a 03 WRX with SPT intake and catback exhaust. I don't have an OBD2 reader, so I don't have the code. Is there any other way to obtain the code? The motor was replaced by Subaru because of a spun rod bearing. During the break in period the only issue I had was the gas peddle was stiff one day than loose another. I checked the throttle cable and is there two of them or is it just me? I have no idea since this is my first Subaru, but the cable on the right is a looser compared to the one on the left.
    Thanks,
    JT
    Borrow a code reader from Autozone
    Aug 2002
    Virginia Beach, VA
    Quote Originally Posted by idipskoalmint View Post
    Which is free and only takes like 5 minutes. Then post the number the guy gives you...
    May 2008
    Elgin, IL
    Well I got in the car after class today to take the car to autozone, and the check engine light has gone away. Any suggestions?
    Aug 2002
    Virginia Beach, VA
    Quote Originally Posted by mdwstinnovation View Post
    If you turn the key on and off three times without the car experiencing the problem that originally triggered the light, it will erase the code....I forget how but there is a way to find out what the code was even if the light is out...
    May 2008
    Elgin, IL
    Well I'll try and figure out how to do that, thanks for the info. If it happens again, Im gunna have to go straight to autozone or some where and get the code.
    Thanks again,
    JT
    Aug 2002
    Virginia Beach, VA
    Sounds like a plan. I bet you a dollar either Testes1010 or Donkey could tell you how to do it...I'll PM them.
    Feb 2004
    Evansville, IN
    Quote Originally Posted by Timdog1650 View Post
    OOoO, a dollar.....cool, I can buy a handfull of gas with that
    The code should show up as a history code, I'm not sure if the standard OBDII readers can read history codes although I would think they would. I generally only use ECUExplorer for reading codes which does show history codes.
    With out knowing more about it, it sounds like a Intercooler(or inlet) hose is holding on for dear life allowing fresh air to enter the intake w/o being metered & during shifting load drops & there no fuel causing the car to die/sputter.
    1988 Celica Alltrac
    Hallman Pro, 15x7.5 +20mm Rota Slipstreams
    2005 LGT 315whp/340wtq@21psi - Sold
    VF52, Crucial P&P&C Manifolds, UP, DP, RP, Magnaflow CBE, Hallman PRO, ROMRaider
    2003 WRX 371whp/355wtq@24psi - Sold
    TD05H-20G-38mm Tial, Meth Injection, Hyperflow TMIC, ROMRaider
    Dyno Chart METH vs 93 oct
    Moderator Donkey's Avatar
    Da boonies
    I think most OBDII readers will show "historic" codes as long as the battery hasn't been disconnected in between.
    2002 FORESTER S
    1998 FORESTER S
    May 2008
    Elgin, IL
    Quote Originally Posted by testes1010 View Post
    I'll try autozone tomorrow and see if they can get the code from history. Where do u get the ECUExplorer?
    So basicly check the hoses and see how they are holding up? Maybe someone forgot to fully tighten one down?
    Thanks for all the help guys, now its time for me to get going on this problem. haha wish me luck!
    Oh and thanks TimDog for all ur help, ur a lifesaver!
