Clutch - Unidentified Problem
Results 1 to 6 of 6
This is a discussion on Clutch - Unidentified Problem within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Guys and Gals I need some help. I have had my 2002 WRX for about 2 years now. It has ...
    Guys and Gals
    I need some help. I have had my 2002 WRX for about 2 years now. It has about 83k miles with no problems and original clutch. The deal is the clutch seems to be slipping when I am starting from a dead stop. Slipping is the best word I can use to describe this phenomenon. Essentially the car acts like it is going to stall out by shaking around despite amble throttle application with slow clutch engagement. It only seems to happen when the car is cold, and will generally fade once the car is at normal operating temp. What do you guys think? Is it time to replace the clutch? Is this common occurance with WRX models? Thanks for your time.
    Registered User justin.jordan2's Avatar
    Feb 2008
    FAIRFIELD, CALIFORNIA
    Quote Originally Posted by Krick View Post
    Guys and Gals
    once the clutch is warm it has a better tendancy to grab. to test it put ur car in third gear going up a steep hill, after letting the clutch out all the way flor it see if the rpms spike and you dont reallly gain speed, then more than likely it;s bad. thats a good amount of miles on a stock clutch.
    COBB FLASHED STAGE 2, UPPIPE, DOWNPIPE WITH HIGH FLOW CAT, AND FULL 3 INCH CAT BACK, 160 CRUCIAL RACING THERMOSTAT, K&N FILTER. TRACK: 1/4 MILE 13.66 102.7 MPH ON THE COBB OTS MAP
    May 2007
    behind the wheel
    if it chatters on take-off, most likely, it's worn, or the flywheel is warped. getting heat in it (after warm-up) will often make the chatter less evident, in some cases.
    I don't think it's slipping, as usually the clutch will slip in a high-load situation (4 or 5 gear, uphill or WOT) if it's in early stages of failure.
    If you ride with your foot 'resting' on the clutch pedal, it could very well be that too much heat has been applied to the flywheel, thus, warping it.
    I think a clutch-set and flywheel are in your near future..
    Rogan o_0
    Thanks for great responses!
    I was starting to think 83K miles is a lot for a stock clutch. Is there any way to decipher the difference between a clutch and flywheel issue?
    Now that you mention the possible chattering dissipation with a warm engine it makes more sense. I can sometimes sense an ever so slight chatter in the clutch even with a warm engine. So, does this mean a flywheel or clutch issue?
    The thing is the problem is so fickle. It just kind of comes and goes with the wind. So it is hard to go drop a bunch of money on problem that is not always there.
    Do you guys know of a broad price range I could expect to pay for a clutch and flywheel separate or together? I realize the price variables like aftermarket parts, dealerships and such. I just want to avoid being ripped off.
    PS No problem getting the foot off the clutch here.
    May 2007
    behind the wheel
    I'd prolly just prep for replacing both..
    what color is the clutch fluid? is it nice and clear, or dark-to-black?
    If it's not nice 'n clear, I'd start off by flushing the clutch fliud and replace it with freshness
    then monitor the clutch issues..
    Rogan o_0
    I like the simple and logical approach. Thanks for your time.
    I will keep you posted on how things go.
