Results 1 to 4 of 4
This is a discussion on Disconnecting Battery, Am I still stage 1? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I recently made my car into stage 1 with an accessport. Im also going to be putting an aftermarket radio ...
    Nov 2007
    I recently made my car into stage 1 with an accessport. Im also going to be putting an aftermarket radio in my car tonight, I was wondering when I disconnect the battery will that affect my stage 1 map's or anything?
    Apr 2007
    8000' up in Colorado
    No, the map is programmed on your ECU.
    Scott
    Nov 2007
    Ahh alright, Thanks I appreciate the fast reply. I wont have worries tonight
    Registered User dspowersports's Avatar
    Jun 2007
    Milwaukee, WI
    When you remove the power, the computer will reset it's learned memory for timing, etc.. Your car won't run quite as good until it re-learns it's most efficient parameters.
    There is a way to fool the computer to relearn it very quickly. Search for vishnu ECU remap trick. I think it gets you back to "close" to what the ECU had before you removed power.
