Results 1 to 11 of 11
This is a discussion on *HELP*URGENT!!! check engine light*HELP* within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; whats up fellas! newbie here! wondering if you guys can help me out... i just bought a used 02 "bug ...
    Jun 2008
    CA
    Question *HELP*URGENT!!! check engine light*HELP*
    whats up fellas!
    i just bought a used 02 "bug eye" wrx, the hks sqv bov was not making the whistling sound i love to hear as much anymore. i do remember the salesman saying that it has a leak. anyways, as i was driving home today & the check engine light came on!!! once i saw it, i immediately got pissed!!! luckily, i have a obII code reader and found the suby codes for it too...this is what popped up: P0420 catalyst system efficiency below threshold
    what i want to know is...what the hell does that mean? is it something i can fix myself or should i take it in to get checked???
    thanx!
    Nov 2005
    Central Florida
    get a stock bpv and put it back on then see if it comes back on
    All We'll Drive
    DIFFERENT STROKES
    POST WH0RE KING
    Jun 2008
    CA
    did you or anyone you know have this problem too?
    Jun 2008
    CA
    Exclamation the solution...
    so i googled the trouble code and found some guy in a forum that post this up:
    - Manual
    -9600 miles
    -P0420 Catalyst efficiancy fault
    - occured while cruising on highway, part throttle, Sunday night. <<[which is exactly what happend to me!]
    -- took to dealer Monday, they cleared and sent me on my way, said "its a computer glitch and there is no fix, I cleared it, it probably won't come back."
    so now thats outta the way, i just have to get my BOV check out.
    Feb 2005
    Charleston
    I highly doubt the BOV caused this code. This code comes from the ECU seeing the downstream o2 (aftercat) switching between lean and rich like a upstream should. A downstream should read stready right around .45v, this is because a correctly operating cat should take in and let off oxygen keeping the a/f steady after the cat. If you have this code either your cat is chemically innactive or more than likely the car has the uppipe, downpipe, or all 3 cats gutted or replaced w/ resonators/strait pipe
    2002 SRP wrx mt sedan
    AP v2.0 stg 2
    Jun 2008
    CA
    nice to know, i will definitely be checking everything out real soon!
    i deleted the code using my ob2 code reader and it has not popped up at all. so far so good!
    thanx alot for the help!
    Are you catless?
    Registered User ElBartoRex's Avatar
    Feb 2003
    Chester Co. PA
    Quote Originally Posted by teeter_7 View Post
    deleting the code just resets the diagnostic sensors. Once your car runs through its full diagnostic cycle, usually 100-300 miles, it will come back. The code basically means you are running no cats or a single high flow cat in your downpipe that is not efficient enough.
    However, running a leaky BOV is going to cause problems in its own. Get a good recirculating bpv or swap a stocker back in.
    A cobb AccessPORT will take care of that code.
    Current: 05 Mini Cooper S R53
    Former: 06 Acura RSX Type-S
    Former: 00 Integra GSR
    Former: 07 Mazdaspeed3
    Former: 04 WRX Stage 2+
    www.jscspeed.com
    Jun 2008
    CA
    ok, so looks like im cat-less. thats why the code popped up. i just bought an HKS hi power muffler i wanna get on my wrx. do any of you know of a good muffler place that guarantees their work in souther california???
    CBE is pretty easy to put on - I would do it yourself.
    Registered User capt'n'caveman's Avatar
    Oct 2002
    so cali
    the cel has nothing to do w/the bov, but get the leak fixed anyways
    your code has to do w/being catless, there are tons of posts on how to fix it....go forth and search
    k&n, sti-hoodscoop, engine mounts, & tranny mount, blitz dtt, catless up-pipe, samco ic hose, greddy CC, cusco f/r swaybars, gutted midpipe, oil cooler, prodrive exhaust & f/r replica sti strut tower bar, gunmetal rota tarmac, goodridge ss lines, p'n'p exhaust manifold
    deny the fly-by
