cruise control not working on 2002 wrx?
Results 1 to 5 of 5
This is a discussion on cruise control not working on 2002 wrx? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; hi all- i have a 2002 wrx with 75,000 miles. recently, i noticed the cruise control was not working. the ...
    Dec 2007
    Question cruise control not working on 2002 wrx?
    hi all-
    i have a 2002 wrx with 75,000 miles. recently, i noticed the cruise control was not working. the light still comes on in the on/off switch on the panel when i push it on. i checked for a fuse and could not find one for cruise control in either fuse box.
    any other ideas to check before i take it to the dealer? any idea how much a replacement cruise control unit would cost if i need one?
    thanks!
    boochydog
    May 2007
    behind the wheel
    make sure the pedal switches are adjusted properly.
    done any work on the car recently? IF so, what/where?
    check fuse #6, and fuse #18
    Rogan o_0
    '97 Dodge 3500 CTD DUALLY built Auto - 40psi boosties - 750 lb/ft
    Dec 2007
    i will go check those fuses. i had my 60,000 tuneup done at about 68,000 miles, but the cc worked after that. i believe i have had the 2004 recall work done for the cc clip.
    by pedal switches, do you mean the length of travel on the pedals when they are engaged?
    May 2007
    behind the wheel
    make sure the plungers are depressed when the pedals are up. you should be able to depress the pedals slightly, and hear a possible 'click' from the switch on the arm(s)
    Rogan o_0
    Dec 2007
    checked fuses and pedals - all seems to be ok.
    any other suggestions?
    i just replaced the cabin filtration system filter - maybe that will help...
