Results 1 to 7 of 7
This is a discussion on Car Revs high after start HELP! within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; after an engine swap in my 2002 WRX my car just revs super high on start up. any input on ...
    Jun 2008
    after an engine swap in my 2002 WRX my car just revs super high on start up. any input on what the problem could be?
    Apr 2007
    8000' up in Colorado
    You don't provide enough info to go on. What exact setup did you put in the car? You need to list everything about your car and exactly what was modified including what tuning has been done to it.
    Scott
    Jun 2008
    alright.
    its a 2002 Wrx ej20 with 560 injectors 225 LPF fuel pump.
    Agency 3 inch turbo inlet tube, CAI, greddy recirculating blowoff,
    port and polished intake manifold and heads. light weight crank pulley, full downpipe back BPM exhaust, HKS turbo timer and mishimoto 2 core radiator.
    Now on start up my throttle just jumps wide open, i am heading in the direction of the idel air control valve or the throttle position sensor. But it very well could be a vacuum leak or plug.
    Any other suggestions that i should maybe check or look into?
    Jun 2008
    also the car throws no codes
    Apr 2007
    Quote Originally Posted by Bobby5448 View Post
    Those all sound like possibilities. What kind of engine tuning are you running?
    Scott
    Jun 2008
    Well to be honest, i am extremely new to tuning and have done nothing yet. If its possible to ask without being laughed at, i would like help with tuning and think it could help the problem.
    From ground 1- Where do i start?
    Jun 2008
    Ill try to be as specific as possible with what the car is actually doing.
    When i start the car it has a slow rising RPM level, I have never just let it run all the way up. I always just shut the car off.
    When i turn the key off i can hear the turbo spool down.
    I have no check engine light because i dont think it has actually ran long enough.
    on my intake manifold i have 2 vacuum line spots and dont know exactley where those 2 go
    The first one is on the front side of the manifold on the left side of the throttle body, it has a 90 degree bend going down
    and the second is on the back side of the manifold and it at the bottom right side of the throttle body. ( From front of car)
    help with those and where they go may be a first step. but i am pretty desperate.
