Results 1 to 11 of 11
This is a discussion on Car bogging at idle please help!!!! within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Hey guys i have an 02 wrx with 70,000 miles on it, when i turn the car on it begins ...
    Registered User jimenezp's Avatar
    Apr 2008
    Hey guys i have an 02 wrx with 70,000 miles on it, when i turn the car on it begins to bog and almost is about to die, it does this mostly when the car is at an idle after it hasn't been driven for a couple of hours. after the car warms up it doesn't seem to do it anymore. I work at toyota and scanned it using OBDII and pulled a code stating the car was running rich. It is really bugging me so please any suggestions of what it may be or what i should check are greatly appreciated thanks. by the way the car used to bog the whole time driving it, but since i replaced the MAF, the car only does it when it isnt warmed up.
    Registered User wunderboy987's Avatar
    Nov 2007
    nj
    do u have a blow off valve?
    Hawk-Eye Alliance #898Military Milita #898
    AP stage 2 93 oct. maddad DP. SPT short ram intake,SPT intake heat shield,HKS carbon fiber catback,boost,MAF,volt gauges,STI springs, pioneer flip screen headunit, polk audio speakers, vortex generator,STI wing,rally armor UR flaps
    Apr 2008
    Just the stock blow off valve
    Moderator Donkey's Avatar
    Da boonies
    What helps is when you list all your engine mods. When did it start acting like this?Have you pulled the sparkplugs and checked them (gap)?Have you tried cleaning the throttlebody and IAC valve?
    2002 FORESTER S
    1998 FORESTER S
    Apr 2008
    The car is stock besides the exhaust. it has an up and down pipe but thats it. no other engine mods. the code pulled was a p0172. system running rich.
    Apr 2008
    no donkey, i have not yet tried those things u listed, but i will. I am hoping it is a cheap fix!
    Aug 2002
    Virginia Beach, VA
    Quote Originally Posted by jimenezp View Post
    Click the link in my signature about diagnosing misfires.
    If I were you I would focus on the MAF, plugs, injectors, and finally the O2 Sensor. One of those is almost certainly the culprit.
    Apr 2008
    Thanks timdog u seem to be a lot of help around the forums i appreciate it. Ill definately check into everything u have said thanks.
    Registered User inky07's Avatar
    Feb 2008
    Hey I also have an 02 that seems to do the same. I am def. running rich but I have a turbo xs blow off and 3 in. cat back exhaust...post up if you figure out what your problem was! thanks!
    Apr 2007
    8000' up in Colorado
    What engine tuning are you using to support the exhaust mods?
    Scott
