Results 1 to 7 of 7
This is a discussion on subaru impreza 2001 wrx awd within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; hi ive recently bought a 2001 subaru impreza wrx awd...the engine management light has come on.i had it put on ...
    May 2008
    hi ive recently bought a 2001 subaru impreza wrx awd...the engine management light has come on.i had it put on the computer and the code it came back with was p0172...cud any 1 please help me with what i shud do..it feels like it is running a little rich because when its ticking over the revs drop below 1000rpm and nearly stalls but then shoots back up.there is definately a flat spot ..cud any 1 please giv me any advice wot i cud do...thanks
    Quote Originally Posted by jame5evan5 View Post
    the code it came back with was p0172...it feels like it is running a little rich
    The ECU thinks it's running rich also. List modifications and service history.
    May 2008
    i know it has a pro drive pack...and had all the regular services..im new to driving 1 of these and the maintaining of 1 so any help would be much apppreciated
    May 2008
    as i said any help would be most greatful..thankyou
    Either the ECU is running the wrong map or there is a problem with fueling and the car is running rick. Check
    02 sensor
    MAF sensor
    Check all vacuum hoses at intake system.
    PCV system
    Throttle body
    IAC (idle air controller valve)
    If you have an aftermarket dump valve swap in a stocker and see what happens.
    May 2008
    is the maf sensor near a big air pipe cos i unplugged it today while the car was running and it just cut out..if not how will i know if it is the maf sensor..as i say im just learning about these cars..what would the 1st thing be best te chek?
    The MAF sensor is on the air inlet and has a harness clip attached to it. The harness should face forward. Run down the list above methodically or take it to a specialist, preferably one that sells/installs Prodrive kits. I assume you are UK? Try scoobynet.co.uk for local help.
