Try diagnosing the misfire starting with the easy stuff. There's a couple of threads on here about doing so, I'm too lazy to retype it all right now.
This is a discussion on CEL @ 50k Miles. More... within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Well I went and did the code scan on the ol AP. It's reporting P0302 which means cylinder 2 is ...
It's reporting P0302 which means cylinder 2 is misfiring. After that it says ok/cancel. I hit ok and it lists ????? as the next thing listed.
Wth could be causing a well cared for car to have a misfiring cylinder? I don't beat on it, It gets the maintenence it should and at 50k miles I shouldn't have any bad plugs yet...should I?
I have a warranty that was purchased with the car, 4 year bumper to bumper. Question is, should I reflash to stock? Stage 1 is hardly something that would cause a problem.
Took it to the dealership that morning and they swapped the 2 and 4 coilpacks replaced the plug in 2. So far no return.
The one thing I never figured out about this car is the super rough idle. It's done that from the day I drove it out of the dealership. It hitches and bucks while sitting at a light or parked in neutral as if it's trying to stall out..yet the Rpms remain steady.
Can you please provide links to definitive proof of this?:
Exactly.
Exactamundo.
Ok so I Googled that and the only thing that popped up was your post.![]()
First you blame M1 for all the bearing failures, then you say "The oil itself does not cause failures. Its the kid who doesn't check his oil level with a "thin" oil in the case." Not only are you contradicting yourself, but the viscosity of the oil has absolutely nothing to do with the oil level! Of course a low oil level is going to cause bearing failures. Doesn't take a genius to figure that out!
Tell me an oil that doesn't get "eaten" in a WRX or in most turbo cars.
Mobil 1 is one of the finest oils available on the market. Otherwise, how could Porsche make the recommended service interval for the Porsche 911 20k miles between oil changes?
Scott
mobil 5w30 thin - Google Search
Works for me.
Dyson UOA; 05 LGT w/ 63k miles on Mobil 1 5w-30.. - Subaru Legacy Forums
I posted a Subaru related one but the 1,000's of ones NOT Subaru related show it's more than just a myth that Mobil's 5W30 had a problem at one point.Not quite sure how you couldn't find that using Google.Try Bob Is The Oil Guy
The M1 5W-30 is IMO an interesting oil. At least in SL form, the 5W-30 was more viscous at operating temperature than the 10W-30 from the same maker, even though the two oils ostensibly shared base formulations and even though, well, one might (naively?) expect a 10W-30 to be more viscous (I realise the reasoning is faulty but mention it for discussion).
I'd used 5W-30 as my initial M1 oil change when the motor was still breaking in. I noticed that the consumption was about the same as with the dealer oil (Valvoline conventional from drums). This amounted to roughly 600 ml per OCI. I didn't quite like that much, even though it didn't pose a problem -- I could drive a full OCI without topping off, just letting the level drop.
Around that time, Mobil decided to repackage Delvac1 as Truck/SUV 5W-40. I used that a lot, got great UOA data, and after the 2nd OCI with that the car didn't use a measurable amount. That oil also stayed in grade for 5,800 miles with plenty of reserve, meaning I could (and probably should!) have gone 7,500 miles between changes just like the manual states.
Meanwhile, the Truck/SUV was split into two lines by Mobil: 5W-40 turbodiesel SL (the same oil I'd been using) and 5W-30 petrol (SM, I believe). The retailers nearby stopped carrying the turbodiesel variant I wanted and only offered the 5W-30, so I switched to M1 0W-40. This is now the SM formulation. The car does use about 400 ml of this per OCI, and the oil does seem to thin out mid-life, but I don't care. The oil thickens back up as it ages according to UOAs I've seen, and whether I top it off or not the car won't be low on oil during the OCI anyway.
The 5W-40 and 0W-40 are not listed in the manual -- if I were under warranty, I'd follow the manual to the letter.
It means there high speed, that with M1 5w-30 the majority of boxer engines' have a considerable amount of excess oil consumption with it.
In turn, most bearing damage is caused by oil starvation.
So put it together.
M1 was reformulated also there Hoss.
Also Rotella-T 5w-40, I (as well as many others) loose less than .3 quarts per 5k mile change interval. Another would be the "German Castrol". Found at most Autozones (0w-30). Been proven by many UOAs to be a good fit for the Scoobys'.
You really need to visit BobtheOilGuy and learn or get a UOA from your precious M1.
I bet you think RP is the best thing since sliced bread also.![]()
WRB, Tial gated 20'gd, PPG reppin Bugeye FTW !
Rogan o_0
'01 Dodge 2500 CTD 6-holed hand-shaker - 3850# dual disk
'97 Dodge 3500 CTD DUALLY built Auto - 40psi boosties
If you break it down, it's 260$ for 20 Qts.
13$/qt., versus what, 7$qt for M1, and what, 9-10$/qt for AMSOIL..
I run SUBARU oil filters.
(14th is the best day to make it, prolly)
Rogan o_0
I've done 3 since January![]()
Rogan o_0
