Urgent!! Yet Another Problem - Check Engine Light Is Comming On..please Helpp!!!!!!
Results 1 to 14 of 14
This is a discussion on Urgent!! Yet Another Problem - Check Engine Light Is Comming On..please Helpp!!!!!! within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I already have a leaking coolant pipe which will be getting sorted out!!! but now I have another problem, when ...
    Jan 2008
    Red face Urgent!! Yet Another Problem - Check Engine Light Is Comming On..please Helpp!!!!!!
    I already have a leaking coolant pipe which will be getting sorted out!!! but now I have another problem, when i start the engine it is starting to stall ocassionally, drives fine then suddenly it will cut out now and again randomly, but it will start up fine after this, then once started up again the check engine light comes on and stays on.
    but once i turn the engine off and on again the light will go out..
    any ideas as what this means??
    thanks in advance guyz
    the car is starting to give me to much grief nw
    Registered User GageP's Avatar
    Dec 2007
    California
    Nt time the light come dont urn it off and take it down to an auto parts store and get there code reader and check the codes. Dont turn your car off when you get there because you may turn the light off and then you wont know what is causing it to come on.
    When you do things right people wont be sure you've done anything at all.
    Crabcakes and football thats what Maryland does.
    May 2008
    in the 209
    check engine light
    even if the light goes out the computer stores it, this is called a hard code. it will be stored for 40 miles or starting the car 3 times with out fault. so check the code and let me know and i can get all the info u need k.
    Jan 2008
    Exclamation Re-
    Any one had any similar problems, is it just me or is the wrx an unreliable car??
    because not being funny, seriously when u fix one thing a week later something else goes wrong, i know its a 1994 car which has been taken care of over the years, but ive heard that even the newer ones have non stop problems, maybe just the car im guessing.
    Apr 2007
    8000' up in Colorado
    What mods does your car have? Year/model?
    Scott
    Jan 2008
    Re-
    Hi Its a 1994 wrx, only mod that i know of is a BOV not sure which 1 but its always been on there, and it has a decat exusst system thats all, al standard apart from that.
    Aug 2002
    Virginia Beach, VA
    Quote Originally Posted by az_e11 View Post
    It's a 14 year old performance car....that should answer your question.
    You won't be able to get someone to read the code on the ECU, it's not an OBD-II car, it's an OBD-I. Take it to a reputable shop and have them diagnose it or find a local WRX owner and have them take a look. There is very little we can do online to help you because you gave a really vague explanation of the problem. 2 sentences is not enough for anyone to get a true understanding of what is going on...
    May 2007
    behind the wheel
    you can code OBD1
    Rogan o_0
    Aug 2002
    Virginia Beach, VA
    you can code OBD1
    Oh, no doubt, but not the way everyone else was recommending. Not only do I not know how to do it on a 94 wrx, I doubt the OP does nor would he know what he was seeing if he did figure out how to get the ECU to spit out the codes it's storing. It's certainly not as easy as just going to Autozone like was previously mentioned in this thread.
    May 2007
    behind the wheel
    Quote Originally Posted by Timdog1650 View Post
    Rogan o_0
    May 2007
    behind the wheel
    real nice...
    Rogan o_0
    Sep 2008
    Pathetic
    I was pointed here searching for answers to a suspected knock sensor inquiry. Instead, I discovered Timdog1650's 4 month old pompous response, complete with Photoshop pics of his girlfriend bowling. Very helpful. What a jerk.
    PS: You're average, and balding...
    May 2007
    behind the wheel
    and you felt the need to bring back a 4 month old thread, that you deem 'worthless'..
    Rogan o_0
