Fog Lights Simple Question
Results 1 to 10 of 10
This is a discussion on Fog Lights Simple Question within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I have an 05 subaru wrx and the passenger side fog lamp is very tainted. I would say its water ...
    Registered User jonthesloth's Avatar
    May 2008
    La Mirada, California
    I have an 05 subaru wrx and the passenger side fog lamp is very tainted. I would say its water logged or something, just that nasty mucky yellowish color has taken over and im wondering what i should do to fix it. Maybe some CLR? would that work?
    Also, neither of the lights work, but the switch does. I checked the fuse so it must be the bulbs. How do I go about changing the bulbs on them?
    Any help will be greatly appreciated
    edit: I believe the fog light covers are glass btw
    May 2008
    in the 209
    fog lamps
    if the vehicle is under warrenty the will replace it for free but if not most dealer detalers can take care of it for u.
    Registered User JMack's Avatar
    Feb 2008
    Quote Originally Posted by subytech209 View Post
    This issue will not be covered under the warrantee unless the issue is in the switch or wiring. Bulbs are expendable dependent upon use and conditions, therefore they will not be covered.
    I would also steer clear of the CLR on the lenses. The lenses are plastic and you may have chem issues with the CLR and the lens. You could use some very light (high number around 3k) polishing compound to take the discolouration off.
    Hope this helps a little bit.
    May 2008
    ok polishing compound... Well that would probably work, but is there any household remedies?
    and can anyone just point me in the right direction on what screw i have to unscrew or something because the fog lights are in the housing fixture and I can't figure out how to get it out to change it. Also what bulbs are they, (I'm sure I will find out once I get them off) and does autozone have replacement ones?
    I just bought my car like 3 weeks ago so sorry for the newbie questions.
    Registered User Feezor's Avatar
    Nov 2006
    Ca
    Here is a tutorial for removal
    Fog lights on an 06 WRX
    May 2008
    in the 209
    fog lights
    if the vehicle is under warrenty the bulbs are covered and also the headlight asmb. so check first. btw i work at a dealership so i know what is covered.
    Feb 2008
    You must work at a very kind dealership, b/c every stealership I've been to, the bulbs are not covered under a warrantee b/c they are expendable. Do you guys change oil, diff lube, brake fluid, fuel, and coolant for free too?
    Success is the ability to go from one failure to another with no loss of enthusiasm.
    - Winston Churchill
    Ah, the patter of little feet around the house. There's nothing like having a midget for a butler.
    I am free of all prejudices. I hate everyone equally.
    - W.C. Fields
    May 2008
    hey since you work at a subaru dealership, can you tell me what warranties i still have on my car. I never bought an extended warranty and I'm not the original owner, I am the 2nd owner. It is an 05 with 43k. Also, if you have ever worked on this job, I tried doing it myself today, when i go to pull out the bulb, just this part comes off and then its connected by two wires. If they tell me its gonna cost money, which i think they might here in orange county/la, then do you have any info for me?
    May 2008
    in the 209
    lghts
    i can tell u but i need the last eight of ur vin # and ya i should be able to help.
    May 2008
    5061 are the last 4
