Premium vs Regular: The octane thread - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 30 of 30
This is a discussion on Premium vs Regular: The octane thread within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Originally Posted by Speedette Side note: do you think you'd see the same increase when using 93 octane versus 96-100 ...
    Registered User jcaputo's Avatar
    Dec 2007
    Shrewsbury MA
    Quote Originally Posted by Speedette View Post
    Side note: do you think you'd see the same increase when using 93 octane versus 96-100 octane (race gas)?
    Quote Originally Posted by Micah View Post
    If the ECU isn't tuned for it, I don't think there would be much benefit other than a better resistance to detonation from the higher octane.
    That's what I was thinking. There should be essentially no change running higher octane on a stock car.
    That's actually why I was curious about the 91 octane versus the 93. There may be more savings to be had if the engine doesn't detonate using 91, and there may be no noticeable difference between 93 and 91.
    I don't have my owner's manual in front of me, anyone know what it actually recommends? Is it 93 or 91?
    '05 silver WRX
    Blobeye Syndicate #28
    Raammat Soundproof Thread
    The Octane Thread
    SuperNova 06wrx4me's Avatar
    Jun 2006
    Nor Cal
    Quote Originally Posted by jcaputo View Post
    WRX recommends 91 oct Sti recommends 93. Nicely done
    2016 Challenger Scat Pack
    1973 Nova
    2014 Ford Fiesta ST <sold>
    COILOVER TABLE
    TURBO TABLE
    Registered User efmd3's Avatar
    Jun 2006
    the ham
    don't forget that generally, higher octane fuels have less energy, but can be more efficient at burning them.
    meaning (i think) if you put 93 in a car tuned for 87, you will get worse gas mileage, but if you tune it for 93 (compression/boost) it can get close to and possibly better gas mileage.
  6. #19
    Oct 2005
    Ocean Grove, NJ
    grain of salt without numbers
    Quote Originally Posted by efmd3 View Post
    What is the actual % difference in energy between octane ratings.
    Anyone have numbers on this.
  7. #20
    Jun 2006
    the ham
    What is the actual &#37; difference in energy between octane ratings.
    E85 fuel FAQ - NASIOC
    Typical fuel energy contents:
    gallon of gasoline = 125,000 Btu
    1 gallon of ethanol = 84,400 Btu
    1 gallon methanol = 62,800 Btu
    1 gallon of gasohol
    (10% ethanol, 90% gasoline) = 120,900 Btu
    1 gallon of E-85
    (85% ethanol, 15% gasoline) = 90,500 Btu
    1 gallon of kerosene or light distillate oil = 135,000 Btu
    1 gallon of middle distillate or diesel fuel oil = 138,690 Btu
    Gasoline - Wikipedia, the free encyclopedia
  8. #21
    Apr 2004
    Southeastern PA
    Quote Originally Posted by Trainrex View Post
    Ray's long lost brother!
    ... hidden away from others ...
    Quote Originally Posted by 20WRX04 View Post
    Nice write up.
    Quote Originally Posted by wrx wagone View Post
    Nice work!
    Indeed.
    Mods & Pics
  9. #22
    May 2007
    behind the wheel
    Quote Originally Posted by 04.SPT.WRX View Post
    was he in that basement, for 24yrs?
    Nice test, though..
    I did something like this a few years ago, just never posted it.
    Rogan o_0
  10. #23
    May 2008
    in the 209
    89 vs 91
    using a low grade fuel will cause a ping and will cause damage to ur pistons, i have seen it so try to plus staying with one grade of fuel is better for ur car.
  11. #24
    May 2007
    behind the wheel
    Quote Originally Posted by subytech209 View Post
    isnt "ping" just another name for the more disastrous sounding "DETONATION"..? Yes.
    Posted octane numbers on gasoline pumps are a result of testing fuel performance under laboratory and actual operating conditions. The higher the octane rating on fuel the less volatile (evaporative qualities) and the slower the fuel burns. Higher octane fuel contains more POTENTIAL energy but requires the higher heat generated by higher compression ratio engines to properly condition the fuel to RELEASE that higher potential energy. In the refining process, fewer gallons of higher octane fuels are yielded from a barrel of raw crude, thus the higher cost. If fuel octane is too low for a given compression ratio, the fuel prematurely and spontaneously ignites too early and the fuel charge EXPLODES rather than BURNS resulting in incomplete combustion. The net effect is a loss in power and possible engine damage. The operator hears an audible "knock" or "ping", referred to as detonation. Detonation may vary from a faint noise on light acceleration to a constant, deep hammering noise while driving at a constant speed. Improper timing adjustments, vacuum leaks, or excessively lean fuel mixtures may also cause detonation. - excerpted from WikiAnswers
    ..wut??
    Rogan o_0
  12. #25
    Apr 2007
    8000' up in Colorado
    Here's another interesting experiement:
    What happens if you use 91 octane in a stage 2 STi with a 93 octane OTS Cobb map?
    Absolutely nothing.
    Why would you want to do this? I just haven't gotten around to loading the 91 octane map on the ECU after moving from Mass to Colorado. Maybe tomorrow...
    Scott
  13. #26
    Registered User pacemaster's Avatar
    Jul 2008
    Nevada
    Thumbs up Octane..
    Thanks for this great info..
    There were a couple of contradictions....though.
    Someone said [detonation] with 87 octane..the ecu doesn't compensate enough?? or does it.. worse milage is great info running 87. Better milage with 93-- where i live at 5000 feet only 91 is available.. maybe 89 is fine at high altitude? Or run the hightest octane i can get and get the best mpg's possible?
    Owned my 06 Rex for two weeks and liking it alot. 23k k on it.
  14. #27
    Jul 2013
    Central Texas
    I must say I do truly enjoy the fact that you went into full details thank you very much for the info... team 93 haha
  15. #28
    Apr 2004
    Southeastern PA
    Quote Originally Posted by YB_WRX_2013 View Post
    Nice bump and great search (I'd think) on your part.
    Mods & Pics
  16. #29
    Registered User Ingo's Avatar
    Mar 2012
    Colorado Springs, CO
    ...and yes, at higher altitude the octane numbers don't need to be quite that high, hence there is only max 91 octane available in Colorado. At lower altitude there is usually higher octane available and should be used. When I took a road trip to Iowa I had that and didn't see any problem. As stated repeatedly, the higher consumption of lower grade fuel plus the danger of causing harm makes it not worth going with lower grade fuel. Back then my wife was not aware that it takes premium - she would have nixed the WRX in a heart-beat. But then it was too late, and she got used to it since. I still have respectable MPG's (20 in city) and that's ok (compared to 20 with regular in a Suzuki sidekick).
  17. #30
    Registered User Miggs's Avatar
    Jul 2013
    North Carolina
    E85!!!!!
