Results 1 to 4 of 4
This is a discussion on weird within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; alright so i have been noticing when i give her a little gas my RPMs jump up for a few ...
    Registered User Dhbamby's Avatar
    Jan 2008
    Lanc Lanc PA
    weird
    alright so i have been noticing when i give her a little gas my RPMs jump up for a few seconds then back down to normal acceleration rpms.....and now i just smelled terrible smelling smoke coming out from under my hood....i poped the hood and it looks like the smoke is coming from right under my throttle body/intercooler area..... what could this be ????
    MY Mods...
    2004 WRX OPB....58k...open source tuned...VF 39 Turbo...Pink 565cc injectors...Walbro FP... Godspeed FMIC...Turbo XS Stealthback Exhaust...Gimmik Turbo Inlet...Gimmik Rad. Hoses...COBB SF Intake...EXedy Lightweight Flywheel...F1 Racing Stage 2 Clutch...Perrin Crank Pulley...Perrin Afta-MAF Hose...HKS Up Pipe...Kartboy Short Shifter and Bushings....lots-o-suspention...
    Registered User justin.jordan2's Avatar
    Feb 2008
    FAIRFIELD, CALIFORNIA
    can you say clutch slipping, the tranny is right under the intercooler, or you could have oil dripping on it too, causeing the smoke and slippage but more than likely just you need a new clutch how many miles you have on it..
    COBB FLASHED STAGE 2, UPPIPE, DOWNPIPE WITH HIGH FLOW CAT, AND FULL 3 INCH CAT BACK, 160 CRUCIAL RACING THERMOSTAT, K&N FILTER. TRACK: 1/4 MILE 13.66 102.7 MPH ON THE COBB OTS MAP
    Quote Originally Posted by Dhbamby View Post
    If the clutch is slipping and you are seeing/smelling "smoke" suspect either the clutch itself and/or the motor's rear oil seal leaking onto the clutch. In either case I'd have someone look at the car locally.
    Jun 2009
    Maryland
    I know it's been awhile but what ever happened. Did you find that your clutch was worn or that your clutch wore out faster?
    How much smoke was it? Must have been enough smoke to cause you to worry about it.
    What did you end up doing. Or did you end up doing nothing at all and the car and clutch still seems to function?
    Thanks
