stage 2 w/o a cbe?
Results 1 to 4 of 4
This is a discussion on stage 2 w/o a cbe? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; is it safe to run stage 2 with a cobb ap v2 without a catback? i had a downpipe, catback ...
    Mar 2007
    phila, pa
    stage 2 w/o a cbe?
    is it safe to run stage 2 with a cobb ap v2 without a catback? i had a downpipe, catback and cobb ap and ran stage2 just fine. as soon as i took off the cbe, my CEL came on and the code was p0851, neutral input circuit low, no idea what that means.
    should i reflash my cobb to stage 1?
    stage2. cobb ap2, spt cbe, invidia dp, perrin up
    May 2008
    Quote Originally Posted by darkmantedge View Post
    hopefully this will help...maybe.
    TSB 16-68-06 P0851 / P0852 Neutral Safety Switch - ScoobyMods
    Registered User justin.jordan2's Avatar
    Feb 2008
    FAIRFIELD, CALIFORNIA
    did you leave the dp on or take that off too.....? reflash to stage 1 you are going to burn up ur turbo with all that back pressure and heat....
    COBB FLASHED STAGE 2, UPPIPE, DOWNPIPE WITH HIGH FLOW CAT, AND FULL 3 INCH CAT BACK, 160 CRUCIAL RACING THERMOSTAT, K&N FILTER. TRACK: 1/4 MILE 13.66 102.7 MPH ON THE COBB OTS MAP
    Registered User bcyb1029's Avatar
    Feb 2006
    Chicago
    if you have a dp then your fine, u don't need a cbe for stage 2
    Tuned by Jorge at P&L, 240.83whp 239.60wtq at 14.8psi on 2.0L with stock td04 (But doesn't run)
