ClubWRX Forum - Subaru Impreza WRX and STi Community and Forums
Go Back   ClubWRX Forum - Subaru Impreza WRX and STi Community and Forums > Tech & Modifying & General Repairs > General Maintenance, Troubleshooting & Accidents.
General Maintenance, Troubleshooting & Accidents. What kind of oil should I put in my car for drag racing? When should I change the spark plugs? How do I fix that rattling sound I'm hearing? Ask your maintenence questions here!
Advertise On ClubWRX
Reply
LinkBack Thread Tools Rate Thread Display Modes
Old 05-07-2008, 12:33 PM   #1 (permalink)
Red face URGENT!!! MY WRX 1994 temp guage going up and down..Please help!!!
Hi there guyz, basically since yesterday I have noticed my temp guage on my 94 wrx has been going really high, unlike how it use to be in the middle, so from this I am guessing the engine is getting hot.
I have checked coolant there is enough coolant in there, and the fans seem to be working as they bring the temp down once they come on, but then while driving the temp shoots back up again.
I have also noticed a few drops of water from somewhere and once i turn the engine off i can hear a hissing noise coming from sum where, does this mean i have a leak somewhere.
Theres no puddles or nefing, just a noise like a kettle which goes away after a good few minutes when engine is off, is this a air leak???
Any ideas??
Thanks in advance guyz
az_e11 is offline   Reply With Quote
Old 05-07-2008, 12:39 PM   #2 (permalink)
Moderator
Supporting Member
SD_GR's Avatar
Quote:
Probably.
Find the source of the noise and the liquid. Post back if you need help fixing it.
__________________
He who drifts drives slowly. Walter Roehrl
Νους υγιής εν σώματι υγιεί.
Själen är större än världen.
Mod, New Member Hangout, Southwestern region, International
SD_GR is online now   Reply With Quote
Old 05-07-2008, 01:12 PM   #3 (permalink)
jeremy96gase's Avatar
Maybe your water pump?
A few drops of clear liquid (IE Water) is normal when you have the AC on, because water freezes to the condenser.
jeremy96gase is offline   Reply With Quote
Old 05-08-2008, 04:19 AM   #4 (permalink)
Red face Re -
Hey guyz..
I had a look and i think ive located the leaking pipe, as can see coolant on the pipe slighlty where its dried off, and the leak noise seems to be coming from that area once the car switched off.
So would this be the cause of my temp guage to be shooting up?? as it does come down when the fans come on.
I have put the following video up and half way through the clip u can hear the noise that i am talking about::
YouTube - wrx noise
Its coming from this area, any 1 know if that is the pipe down there that will need changin, if so is it hard to do??
Thanks in advance for ur help guyz
Old 05-08-2008, 04:23 AM   #5 (permalink)
justin.jordan2's Avatar
SHOOTING UP AND DOWN WATER TEMP... it sounds to me like ur thermostat is closed or stuck closed til its forced open by pressure not the heat like it is supposed to.... i would check that. first cheap and easy to change
__________________
COBB FLASHED STAGE 2, UPPIPE, DOWNPIPE WITH HIGH FLOW CAT, AND FULL 3 INCH CAT BACK, 160 CRUCIAL RACING THERMOSTAT, K&N FILTER. TRACK: 1/4 MILE 13.66 102.7 MPH ON THE COBB OTS MAP
justin.jordan2 is offline   Reply With Quote
Old 05-08-2008, 04:23 AM   #6 (permalink)
Red face
And also i dont know if this is a silly question, but when checking if i got enough coolant, do i top up from resovoir on the right hand side near the battery, or the other silver metal 1 more towrds the left of the engine bay.
Whats the difference?
As looking at them they both lead to the radiator.
Any ideas?
Thanks in advance
Old 05-08-2008, 04:25 AM   #7 (permalink)
Any ideas?
Thanks in advance
the one on the left side goes to the turbo. fill up from the resavoir... the coolant will be sucked in the engine as needed. check ur theromstat..
__________________
Old 05-12-2008, 09:24 AM   #8 (permalink)
Red face Re
To update I have now found the leak, however it is hard to locate which pipe exactli it is leaking from so am finding it hard to describe the hose to the parts department at subaru.
The pipe is further down from the turbo it is near two other pipes and can be felt from under the car.
Any 1 have a schematic diagram for the coolant system???
That would of great help, not sure of how to go about this.
Thanks.
Old 05-12-2008, 09:32 AM   #9 (permalink)
ajd111's Avatar
Sounds like a water pump problem to me. I have a friend whos 2.5RS is doing this at the moment, and we have pinpointed the problem to the pump.
__________________
Quote:
Originally Posted by BrianH View Post
Careful, I still think she's packin wang.
ajd111 is offline   Reply With Quote
Old 05-12-2008, 05:56 PM   #10 (permalink)
Re-
Oh rite i see, i will have to look into that jjust to make sure its not the pump!!
has any one got a rough idea of wear abouts the water pump is located??
thankss peepz
Reply
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin® Version 3.8.2
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.1.0
Copyright 2001-2008 ClubWRX.net
Inactive Reminders By Icora Web Design
