Recharge A/C
Results 1 to 3 of 3
This is a discussion on Recharge A/C within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I have a 2002 wrx and the a/c is blowing hot air I have read it could be an expansion ...
    Registered User morphine16's Avatar
    Oct 2007
    Recharge A/C
    I have a 2002 wrx and the a/c is blowing hot air I have read it could be an expansion valve problem. And i hear a lot about people recharging the a/c...Is this just adding more freon into the system. Im a car noob so if any one could explain how i go about doing this, it would be greatly appreciated! Also how could i check if something is wrong with the expansion valve?
    -Thanks
    2002 bugeye - R.I.P
    2008 hatch - Perrin stage 2
    Oct 2007
    Bump?
    2002 bugeye - R.I.P
    May 2008
    in the 209
    a/c
    first check the fitting and where the rubber hose is crimped to the metal line, is any of the areas caked with durt. if so u have a leak from there. replaced the line or o-ring. to recharge ur a/c right u need to do a vac and charge on it and u should take it to a shop. let me know if that helps.
