Page 1 of 3 123 LastLast
Results 1 to 15 of 37
This is a discussion on total loss of power at high rpm within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Hey ya'll. I recently started having a problem with my 03 wagon. When I push the car (around 5k rpm) ...
    Mar 2007
    Richmond, KY
    Hey ya'll. I recently started having a problem with my 03 wagon. When I push the car (around 5k rpm) I am experiencing a total loss of power. The first time it happened I thought just hit the rpm limiter and the car continued to run with no power for a minute or so. The second time it happened the engine totally died. I have also started to notice a loud hiss and the turbo seems to sound like a VW bug? Otherwise, the car runs fine... I am currently running a Cobb AP Stage 2, Cobb up- and downpipe, and a K&N air filter. The filter is relatively new, as are the plugs...not sure about the fuel filter. I tried digging around b/c I know you guys don't like to be asked the same questions repeatedly but I couldn't really find any specific to my problem. Thanks, in advance, for the help.
    2003 WRX wagon in silver
    Cobb up- & downpipe
    AP Stage 2
    Whiteline F & RSB; Prodrive springs
    Would Never, Ever Say Something Bad About an Admin's Mom SonicWagon's Avatar
    Jul 2007
    Santa Cruz New Mexico
    any CEL codes?
    "It is at our most challenging times that we must cheat our very hardest" - Eric Theodore Cartman
    Quote Originally Posted by Weasel 555 View Post
    so whose up for been banned?
    I is teh b1ggest douche evarrrr!~
    Registered User scoobe's Avatar
    Apr 2008
    Barrington IL
    weird i have the exact same thing going on. my 03 use to shoot me back into my seat when i first got it 3 weeks ago and now im feeling a total loss of power. i have a hissing noise also and have been told by mechanics its a vaccum hose leak, i thought it was coming from the turbo all along.
    i was having a cylinder 4 misfire since i bought the car but it stopped and i got new plugs in today and there arent any codes being thrown
    Mar 2007
    Richmond, KY
    loss of power
    Negative, no codes have been thrown...after the loss of power, the car runs fine with no indication that anything was ever wrong. I reflashed and babied the car for about a week hoping that it was just the ECU wrestling with the AP but I got on it yesterday and it acted like it wanted to do it again, i.e., it hesitated above 5500 rpm.
    Cobb up- & downpipe
    AP Stage 2
    Mar 2007
    Richmond, KY
    Quote Originally Posted by scoobe View Post
    OK, so did you get it fixed? I suspected that it may be a vacuum leak but wasn't sure b/c it only happens when I push the car...it idles fine? Have you done any mods to the car? I thought it may have had something to do with the install of the uppipe...maybe a leak at the gasket?
    Cobb up- & downpipe
    AP Stage 2
    Registered User RLR257's Avatar
    Apr 2008
    my 06 is doing the same thing. just got the car about a month ago. i tried to put these headers and uppipe on but decided not to. so i bolted the stock parts back up. i have a catless dp and exhaust and havent gotten any CELs until i started messing with the uppipe. took it to the mechanic and they said it was the rear o2 sensor. i also noticed that since ive had the CEL i have had a loss of boost and a rather annoying high pitched sound when i get on it. im only pushing 5 to 6 psi now. where before the CEL it was about 11psi. i bought the perrin o2 simulator, wired it up, not sure if its wired right but it hasnt come back on yet. i still get the weird sound and loss of boost when i push the car. any suggestions?
    Jul 2007
    Quote Originally Posted by RLR257 View Post
    your on a mission to destroy that 06 huh?
    Apr 2008
    im on a mission to get it fixed... which is y im just gonna take it to the dealer. it just started last week. i just wanted to get some insight. i know somebody else with an 06 and he didnt have to go through any of this with same mods.
    Jul 2007
    dont take it to the dealer in the condition it is in, they will void your warranty instantly...
    did you friend have engine management or a tune?
    Apr 2008
    no he has neither a tune or em
    Apr 2008
    he has helix dp and exhaust. i have invidia dp and exhaust. thats it... both catless
    Jul 2007
    catless 2.5l with no engine management is going to cause rear 02 and exhaust gas temp CEL lights and more.
    as for you boosting 5-6psi, check for boost leaks and do a smoke test
    it sounds like if it is mechanical its your turbo or a hose is loose
    Is your boost solenoid working properly?
    Mar 2007
    Richmond, KY
    Quote Originally Posted by SonicWagon View Post
    OK, let's not get offtrack here...me, me! What is this smoke test and will it help the poor OP? BTW, I don't have a boost gauge so I don't know what I'm running...
    Cobb up- & downpipe
    AP Stage 2
    Apr 2008
    im just going to put the stock dp back on and take the o2 simulator off until im ready to get a tune or until i get an AP. maybe the loss of boost is a fail safe for having an open dp and in turn pushing more air over the rear o2 sensor than it was calibrated for. the first week or so that i had the dp on, i had no CEL, no loss of boost, nothing. then both came at the same time. so maybe they are linked some how some way. i read in one of the other forums that the 06-07 models are way more sensitive to bolt ones than the 02-05 models. found that out after i put the dp on though.
    if i do get an AP though, i would have to reflash back to stock in order to get an OS right? or what's better, getting an OS pro tune or an AP pro tune?
