Page 3 of 3 FirstFirst 123
Results 31 to 37 of 37
This is a discussion on total loss of power at high rpm within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Originally Posted by Destros Around 40 ft./lbs. for uppipe to manifold and downpipe to CBE. Around 30 ft./lbs. for manifold ...
  1. #31
    Mar 2007
    Richmond, KY
    Quote Originally Posted by Destros View Post
    Around 40 ft./lbs. for uppipe to manifold and downpipe to CBE. Around 30 ft./lbs. for manifold to head, and everything else. Torque evenly too. You would definitely lose power with an exhaust leak, pre-turbo. That's what spins the turbo. Manifold to uppipe gasket is a common leak point.
    Sounds like that may fit the bill...I will check into it. Only a pre-turbo leak would cause this right? I cleaned the MAF sensor and changed the fuel filter but have yet to check the gapping on the plugs. I will use a process of elimination as I get the time. Thanks for the help...
    2003 WRX wagon in silver
    Cobb up- & downpipe
    AP Stage 2
    Whiteline F & RSB; Prodrive springs
  2. #32
    Registered User Destros's Avatar
    Apr 2007
    Springfield, VA.
    Did you just change you plugs? If not, I don't think the gap is your problem; unless of course if you've never changed the plugs... Check out :: Crucial Racing Systems - The parts you need for the performance you want. Those gaskets do not leak, ever.
    -created in the ominous shadow of The Great Vassar-
    Blobeye Syndicate #Eleventy-Seven
  3. #33
    May 2008
    Post no power after 2300 please some body help !!!!!!!
    hey there rexy buddies im new to this site .
    i own a 2000 model black ltd model automatic
    about 3 weeks ago my car just started lacking power, pretty much no power.
    pretty much after 2300 where my turbo should start to build
    power . i put a boost gauge on and its only hitting 5psi
    so far i have replaced spark plugs with new platium NGK ones
    new spitt fire twin core leads
    new inlet manifold gaskets
    new sti injectors
    new vf 24 turbo
    new silicone turbo pipe {from turbo inlet to airflow meter }
    new vaccum hoses and tee peices
    new apexi pod filter
    new front mount intercooler
    new knock sensor
    new fuel filter
    i think thats about it
    and i have run out of idea on what it could be
    and im pretty mechanicly minded
    i have even put it on a scanner and all that came up was knock sensor . so i replaced it and it still comes up so no idea
    i was thinking my next step would be
    new walbro 500hp pump and a haltech piggy back unit
    to get rid of the air flow meter
    which is a common problem with rexys
    and convert to sti 5 speed manual .
  4. #34
    Mar 2007
    Richmond, KY
    Long overdue follow up...bad fuel pump. i noticed that the sound of the pump I would always here when I first turn the key started was different and took it in. The shop said that was ticket, replaced it, and there have been no problems since.
    Cobb up- & downpipe
    AP Stage 2
  5. #35
    Nov 2009
    Thanks for the update. This may one day help another member.
  6. #36
    Apr 2009
    Denver, CO
    One of the subaru shops I've been to in town diagnosed a vacuum leak in my 04 by spraying brake cleaner in the suspected areas. It'll drop the idle down for a while and once it completely evaporates, your idle returns to normal. Mine was a loose worm clamp on a rubber hose. I also had a serious loss of power around 4500 when it slipped off. After everything was tightened down, I stomped on it in 3rd gear and changed my pants, just how I like it
  7. #37
    Aug 2009
    Canada/Ethiopia/Madagascar
    Holy follow up! I know what a dead fuel pump feels like. I was doing a WOT 3rd gear pull when mine died. I assumed the worst at first, broken p/u tube, snapped timing belt... A surprising number of OEM fuel pump failures on WRX's.
    ...Rob.
    [my photos]
