Results 1 to 3 of 3
This is a discussion on Idle Problems within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I have recently started my Impreza up for the first in about 8 months. It is idleing at around 2k ...
    Jul 2007
    Idle Problems
    It is idleing at around 2k and wont drop down
    I have read the ECU fault codes and got error code 24 and 31 any ideas on an easy fix?
    Thanks Sean
    Resident meany-rator 06wrx4me's Avatar
    Jun 2006
    Nor Cal
    Quote Originally Posted by Sean_wrx View Post
    Thanks Sean
    My guess would be bad gas and a possible bad battery.
    Registered User jeffmm06's Avatar
    Sep 2007
    Sacramento, CA
    Im assuming these are the codes you meant by the numbers posted...
    P0031 - Front oxygen (A/F) sensor heater circuit low input
    P0024 "B" camshaft position-timing over advanced or system performance (Bank 2)
    31 sounds like the front o2 is going bad or went bad.
    2005 WRB WRX "was" STAGE 2
