Thanks for evryone who helped me with my timing belt problem. I now have another issue which i need help with. My air flow meter has been damaged and needs replacing (due to using an oil filter - didnt know such a small issue could create such a problem). I have been qouted 700 for a new one in perth, Australia. Does anyone know if this is a reasonable qoute or is the mechanic taking advantage of my lack of knowledge in this department. I have also been told that if im going to spend the 700 i could instead get an aftermarket ecu and then i wouldnt even require an air flow meter. does anyone know if this is true?
