Blew Head Need Help!
Results 1 to 14 of 14
This is a discussion on Blew Head Need Help! within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; So, while i was driving my 2002 WRX my spark plug ripped out of the threads and made my car ...
    Jul 2006
    So, while i was driving my 2002 WRX my spark plug ripped out of the threads and made my car undriveable. i took it to an auto shop and they put in some hela-coil and it worked for a couple of months then blew out again. So i have a couple questions. I would like to know how this could of happened and how i could prevent it? I would also like to know what i should do next? I have a couple of options. I could buy a jdm engine and just swap it out (most expensive), change the heads (approximately $600 each and would like to get 2), or swap my engine out with another model (i.e. legacy). Please any suggestions would be nice, also if you have another suggestion to fix it let me know. Thanks.
    SuperNova 06wrx4me's Avatar
    Jun 2006
    Nor Cal
    How does one "spit out spark plug threads" ? Were the plugs installed wrong? and cross threaded?
    How many miles on your car, and mods?
    2016 Challenger Scat Pack
    1973 Nova
    2014 Ford Fiesta ST <sold>
    COILOVER TABLE
    TURBO TABLE
    Jul 2006
    I dont know how this has happened. My dad is saying that the spark plug could of been loose and the rattled out. When i was at the auto shop the guy called Subaru and they said it could be cause my boost pressure is too high, but i dont see how since it should be stock. Also when this first blew out i had no known mods (i am not the original owner and anything he had done to the car is unknown), and then i added a cold air intake when i got it fixed the first time. Thanks. Also i have 60,000 miles.
    Jun 2006
    Nor Cal
    Quote Originally Posted by smitt04 View Post
    I dont know how this has happened. My dad is saying that the spark plug could of been loose and the rattled out. When i was at the auto shop the guy called Subaru and they said it could be cause my boot pressure is too high, but i dont see how since it should be stock. Also when this first blew out i had no known mods, and then i added a cold air intake when i got it fixed the first time. Thanks. Also i have 60,000 miles.
    I have never heard of this happening under normal conditions.
    1973 Nova
    COILOVER TABLE
    TURBO TABLE
    Jul 2004
    Seattle, WA
    Cold air intakes make the car lean out, but I have no idea why it would do that in the first place, let alone a second time.
    Jul 2006
    I've seen spark plugs back out (twice in 20 years) but it's just been a matter of screwing the plug back in with no other worries.
    Jul 2006
    bump
    Jul 2006
    bump
    May 2007
    behind the wheel
    for starters, no real need for the same questions to be posted it two separate threads..
    The second time that the plug came out (with the heli-coil threads) are the helical threads still in?
    They are usually Stainless Steel, so I'd be highly surprised if they are torn out, unless they pulled out of the aluminum, in which case were improperly installed.
    It is, agreeably, a weird situation, and I've only seen this one time in 40 yrs..
    Rogan o_0
    Aug 2002
    Virginia Beach, VA
    If your head is really truly toast, I would try to get a JDM v8 longblock. More stout bottom end and the heads are night and day better than the USDM WRX heads. That's only "if" the head is truly trashed.
    Twice in 20: Toyota 20R and Toyota 5S-FE. Both times, simply replacing the plug resulted in trouble-free running for tens of thousands of miles (actually, about an additional 100,000 and counting on the 5S-FE since then). I assumed the plug wasn't torqued correctly, put it back in, assumed it's semi-frequent or at least known (especially the second time it happened) and went on with life. No idea how/why/background.
    Jul 2006
    so, i decided to see how much damage there was today. After taking out my battery and windshield wiper fluid i was able to pull out my spark with my hand. after unbolting the the ignition coil and inspecting it, i noticed that the spark plug boot was split down the side and that the boot broke off the coil pack. The coil pack was also bent at a 90 degree angle. Looking closer at the spark plug i was able to see that it looks like the heli-coil dislodged and was stuck on to the spark plug.
    Jul 2006
    bump
