smoke from under the hood - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 22 of 22
This is a discussion on smoke from under the hood within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; OK, see if you can figure out whether what you're smelling smells like burnt WD40....
    Registered User boostin_ass's Avatar
    May 2005
    Roseville, CA
    smells lilke burning tires
    04 Java Black Pearl Wingless WRX:
    5% Tint all around, 10" windsheild strip, 2 pod gauge frame, Turbo and Volt Gauges, Tien S-tech Springs, Progress adj. Rear Sway Bar, Front and Rear Tower Braces, Sound System/DVD, Tsudo Cat-back exhaust, Black housing headlights, Invidia uppipe, Bosal Downpipe, Train Horn, Elbow Silencer Delete, DIY I/C Water Sprayer, 4300K H.I.D.'s
    Registered User GageP's Avatar
    Dec 2007
    California
    check to see if you have a crack in your radiator. I had one and smoke only came out when i was at atop and then when i started to move it went away. The crack was on top and shot coolant on the AC compresser and engine.
  6. #19
    May 2005
    Roseville, CA
    Quote Originally Posted by GageP View Post
    the smokes coming from around the turbo and uppipe connection
  7. #20
    Dec 2007
    California
    check to see if there is a crack in your intercooler. Unless you have a front mounted one.
  8. #21
    May 2010
    i am having the exact same problem. it is burning oil i know this cause my oil level is getting lower by the day. it looks almost like it could be the oil return line but i cant see exactly where its coming from without taking a few things off. if anyone figured out the solution to this problem it would be greatly appreciated
  9. #22
    Registered User Sunkist's Avatar
    Mar 2002
    Tucson, AZ
    The oil return line under my turbo was going bad and oil was all over the place causing light smoke to come out. I just changed the hose when I got a new turbo/engine. Oh and I could see the buildup if I went under the car and looked up at the turbo.
    My woman hates the money pit
    2002 WRX Hybrid 2.5L 16G
