Results 1 to 15 of 19
This is a discussion on hesitation/backfires within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Whenever i give it gas it does not go anywhere at all. I was driving on the highway and i ...
    Registered User AdmWrx's Avatar
    Harrisburg
    Whenever i give it gas it does not go anywhere at all. I was driving on the highway and i couldnt get it to accelerate without it backfiring and having huge hesitation. As soon as it gets into boost it will basically shut down. any ideas?
    Oct 2005
    Ocean Grove, NJ
    MBC? BOV? CAI?
    Do you have any of these?
    Harrisburg
    i have an ebc, hks bov and a blitz air filter
    Oct 2005
    Ocean Grove, NJ
    LOL
    Holy Tri-fecta of fukkups
    These are all bad mods for your subaru. The factory Electronic Boost Controller is what you should be using. Get rid of the BOV and put the stock BPV back on. Ditto on the intake.
    Your WRX is going to be very picky about mods - start using the search and you'll learn why.
    ::edit::
    On second thought the Blitz intake might be ok - I'm honestly not sure.
    How much boost are you running? Have you done anything regarding engine managment?
    Sammich Makin' Princess Leia wrxtreme06's Avatar
    May 2007
    orlando flawduh
    Quote Originally Posted by AdmWrx View Post
    desiree
    06 impreza wrx tr
    : cobb stage II - protuned by STi_Mikey!
    hawk-eye alliance #11:11 //
    wingl3ss @ll!ance #17 // lvl 80 N.E.R.D.
    facebook
    Harrisburg
    it came with them, i read they were bad after but it never ran bad before and ive had it for a year. boost was 14
    Oct 2005
    Ocean Grove, NJ
    14 isn't asking too much. I'm not sure if PTFB would be the issue. Might be worth looking into I guess.
    You could try resetting the ECU, but honestly - nearly everyone here is going to tell you that a BOV is a bad idea. There's some links in my sig for BOV and Bugeye owners - give them both a quick read.
    Harrisburg
    thanks man, yea ill try reseting the ecu. But do you think it might be a fuel filter/pump or anything else?
    Oct 2005
    Ocean Grove, NJ
    How many miles are on the car? Have you followed the recommended maintenance schedule?
    Harrisburg
    Almost 70k miles and yes. Just wondering if it could be dirty or something, seemed like it just wasnt getting gas when i accelerated. I alwasy use 93 as well.
    Oct 2005
    Ocean Grove, NJ
    If you're getting afterfire (I'm fairly sure it's afterfire as if it was backfire you would have bigger problems), then I'd say the fuel system is working. Maybe you want to check your plugs?
    Then again, I'm no mechanic - I've got a few friends who are - and I bounce questions off them all the time. I stopped working on my own cars when I started buying imports. It's about income, free time, and getting tired of having to do the same job more than once. My recommendation is to find a good shop and have them check it out. All the work on my car has been done by Precision Tuning in Lakewood(NJ) and I have no complaints.
    Apr 2007
    8000' up in Colorado
    The problem here is that until you remove the bad components that could be causing problems, you're going to have a hard time identifying why the new behavior is happening. Some small other change may now be interacting with all of those 3 bad mods and now making them cause problems. Or cumulative effects of those bad mods may just now be causing problems. Ultimately, you need to get the car back to a good, reliable, solid baseline by removing the parts that are known to cause problems before you can start troubleshooting what's wrong now.
    Scott
    Apr 2008
    I have an 03 WRX as well and mine seems to do the same thing it hesitates and or bucks and backfires at about 5 grand if i floor it i took it to the dealership they replaced the fuel pump plugs and a gang of sensors by following my check engine codes and none of it worked they made me come get it and charged me a grand they say it needs tuned that the problem is theres to much gas to my air ratio????????????
    Moderator Donkey's Avatar
    Da boonies
    The bucking /backfiring usually had two culprets.Dirty MAF or clogged fuel sock.Are you guys getting DTC/CEL's?
    2002 FORESTER S
    1998 FORESTER S
    Harrisburg
    i dont have a cel
