hesitation/backfires - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 19 of 19
This is a discussion on hesitation/backfires within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; cel = check engine light my 02 has an mbc, I'm going to take it off, my question is do ...
    Registered User losinspace's Avatar
    Mar 2008
    Arizona
    my 02 has an mbc, I'm going to take it off, my question is do you just connect the 2 ends together and the computer controls the boost or do I need to replace it with something?
    Mar 2008
    Arizona
    Oops, a little preemptive... I found a thread describing the question I asked!!!!
    Registered User budahrocket's Avatar
    Sep 2007
    Agoura Hills
    The problem here is that until you remove the bad components that could be causing problems, you're going to have a hard time identifying why the new behavior is happening. Some small other change may now be interacting with all of those 3 bad mods and now making them cause problems. Or cumulative effects of those bad mods may just now be causing problems. Ultimately, you need to get the car back to a good, reliable, solid baseline by removing the parts that are known to cause problems before you can start troubleshooting what's wrong now.
    ^listen to this man
    and +1 on cleaning the maf sensor
    '02 PSM WRX stg 2
    '67 camaro (my dad's, but hopefully one day i can delete these parenthesis)
    bugeye mafia #161
  6. #19
    Apr 2008
    The bucking /backfiring usually had two culprets.Dirty MAF or clogged fuel sock.Are you guys getting DTC/CEL's?
    i didn't at first but later did the dealership cleared them and threw all this **** on it i drove it again after and it came on again i said **** it because if i can't fix it im trading the pos in, but then it went away but the hesitation is still there
