Results 1 to 4 of 4
This is a discussion on Car Occasionally Overheats within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I have an 02 WRX with 104k on it. The problem I have is that the car starts to get ...
    Apr 2007
    I have an 02 WRX with 104k on it. The problem I have is that the car starts to get warm when it's not moving. The first thing I thought was that the coolant fans weren't coming on, but I have verified that they do work. I am wondering if they are coming on all the time though. It does not overheat everytime I let it idle so I'm wondering if the fans are intermittently working. Anyone have any ideas on what to check?
    Registered User jeffmm06's Avatar
    Sep 2007
    Sacramento, CA
    Any coolant leaks? Coolant levels low?
    No?
    If not i bet the thermostat is stuck causing the overheating.
    Solution: Replace it.
    2005 WRB WRX "was" STAGE 2
    Apr 2007
    Quote Originally Posted by jeffmm06 View Post
    No?
    That was my other thought. Timing belt is getting done in the next couple of weeks so the waterpump and thermostat are getting replaced then. Thanks for the reply though.
    No coolant leaks and it's never low.
    OK, if the pump and thermostat are replaced the problem is IMO unlikely to persist. If it does nonetheless, look for a clog somewhere -- suspect the radiator first. I doubt things will go that far though.
